08-17-2011, 01:52 AM | #1 |
Rep 532
Tyre pressure question summer v winter
So gurus - should the tyre pressures be different for summer and winter tyres and specifically what do you advise for a 3.0d on 225/60 R17 non-run flat Dunlops (summer and winter) for a driver and little additional load? Thanks.
08-17-2011, 02:34 AM | #2 |
Rep 412
Check the instruction book for tire pressures for the size of wheel and tire that matches your winter setup. If you have TPM that should tell you when to put air in. During winter as the temperature drops I check tire pressures using a hand gauge and put in air accordingly.
08-17-2011, 03:01 AM | #3 |
Rep 532
Thanks. I think someone on here was offering more detailed advice than the manual offers, which is 2.2/32F and 2.4/35R with no mention of summer/ winter. I use a digital pump with a guage.
08-17-2011, 05:33 AM | #4 | |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
http://www.tirerack.com/about/techcenter.jsp see the section: Air Pressure - Tire Inflation |
08-17-2011, 08:57 AM | #5 |
Rep 614
@X3buyer: as a good buffer for winter
- inflate them upto specs for 5 passenger loads - measure while tires are cold and note the temperature outside - example, 5 Celcius: when temperature dips to -10C, your tyres would have lost 3psi. your buffer helps in this situation general guideline is 1 psi reduction for every 5C drop. |
08-17-2011, 09:05 AM | #6 |
Rep 412
There should be no difference, maybe add a LB to each corner. The key is regular monitoring as the temperature drops. If you remember Boyle's Law from grammar school physics (PV/T) you should be fine. For imperialists this means roughly 1lb for every 10F temperature change.
08-19-2011, 04:49 AM | #7 |
Rep 125
When I first picked up the car (last Wednesday) pressures were 2.05 F vs 2.25 R according to my Michelin digital gauge, so quite close to what manual says. I don't know if they came like that from the factory or dealer readjusted them before delivery. Dunlop RFTs 225/60R17 .
