      08-22-2014, 01:17 AM   #1
mfoto
Drives: 2007 bmw x3
Low speed vibration
I have a 2007 x3 and from a dead stop after easy acceleration i feel a small but noticeable vibration. the vibration goes away as speed increases , the vibration is not felt in the wheel so i dont beluieve it to be in the steering or wheels. any ideas?
      08-28-2014, 03:06 PM   #2
MiniMouse
Drives: 2007 X3
Had exactly this issue a couple of months ago in conjunction with squeaking from the rear, especially when backing up.
The squeaking was a bad differential, and the vibration required replacing one driveshaft and one rear axle.
      09-06-2014, 08:46 PM   #3
mfoto
Drives: 2007 bmw x3
how many miles do u have on ur X3 . and how did they determine which drive shaft was the one causing the vibration
      01-26-2015, 11:38 AM   #4
TYGIXXER60
TYGIXXER60's Avatar
Drives: 06 X3 3.0I
does the vibration get worst with speed before it disappers? does it feel like rotational vibration in drivtrain or does it go with rpm or your engine?
      12-30-2016, 02:49 AM   #5
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
I have same problem at 40-50 kmh I think it could be something with rear propshaft
