      03-02-2014, 03:12 PM   #1
pacecapt
Drives: 2022 X3 M40i
2014 BMW 435i  [0.00]
2013 BMW X3 28i  [0.00]
Tire Pressure Gage
I am looking for recommendations on purchasing an "accurate" Tire gage. I have several and they all read different PSI. Any suggestions?
      03-02-2014, 07:06 PM   #2
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
You can code it so that you can see them in the idrive
      03-03-2014, 07:04 AM   #3
pacecapt
Thanks, yes I have already done that. The question was in general as I have three other vehicles (no TMPS) that I regularly check pressures on as well.
      03-03-2014, 10:11 AM   #4
Pitiful Old Man
Drives: 2011 X3 35i
I use a Moroso gauge similar to 89560 model on Amazon for $43. Can't attest to its absolute accuracy but, more importantly, it seems to provide very repeatable readings to a half psi or so.
There are a lot of digital gauges out there and you can spend some big money (see Longacre temperature compensated gauges, for example) for a truly accurate gauge. I'm sure the F1 boys can recommend one in the thousands of dollars!
I like the Moroso. It's well armored with a heavy rubber enclosure and has a bleeder valve so you can overfill the tire (slightly) and bleed off the excess to obtain a precise pressure.
      03-03-2014, 10:40 AM   #5
RhoXS
Drives: 2002 Z3 3.0i + 2016 X3 28i
Caution on the digital gauges, they do not work when cold (twenties and lower - depending on the gauge).
Had to buy a standard rising stem gauge during first cold snap this winter because my whammydyne digital gauge would not work unless it remained warm. Even when I carried it outside from a warm interior, it cooled off so quickly it became unusable before I got to the second tire. Granted the temps were in the twenties or lower but the rising stem gauge worked perfectly, cost less, had no battery to go dead, and was 100% dependable.
      03-03-2014, 10:41 PM   #6
fjrmann
Drives: 2011 BMW X3 X35i
I have a Milton 506 dual head inflator. Absolute top quality analog slide gauge.
See:
http://www.amazon.com/Milton-S506-Du.../dp/B0002SRL20
      03-05-2014, 12:02 AM   #7
96_Impreza
96_Impreza's Avatar
12
Drives: 96 Impreza,07 Vette,11 X3 35i
I bought one of these and then five more for gifts. No batteries required! Always works! Accurate, precise and agrees with my 0-40 psi $50 analog Moroso gauge and a bag full of digital gauges that are always in need of a new battery.
Professional Products 11101 Street Tire Pressure Gauge, 0-60 psi.
http://www.amazon.com/Professional-P...cts+tire+11101
      03-12-2014, 07:23 AM   #8
pacecapt
Thanks for all the recommendations I will check them out.
      03-12-2014, 07:56 AM   #9
n55x3
Drives: n55 BMWs
I have 2 Joe's Racing guages. They are well made and relatively cheap @ $22. Works great and feels like it will last a long time.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Extremely good ratings and number of ratings is what initially turned me on to this product.
      03-12-2014, 09:11 AM   #10
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
I bought this one from the dealer
http://www.amazon.com/BMW-82-12-140-...bmw+tire+gauge
Been meaning to compare the accuracy to other gauges that I have.
