      02-16-2021, 07:52 PM   #1
SM2
SM2's Avatar
Drives: 2015 Audi S6 | 2017 BMW M2 | 2
Heated Steering wheel Retrofit problem!
2016 X4 28i M sport
Running into ground issues.
My two ideas.
-Low battery issue has been tripping the system.
-New clock spring is needed for the heated steering retrofit.
Current Parts:
New steering wheel
Column switch and plastic cover.
      01-18-2023, 10:15 PM   #2
rudyv1
Drives: 2008 135i Convertible
Did you ever figure this out and get the heated function to work?
Thanks
      01-19-2023, 08:57 AM   #3
SM2
SM2's Avatar
Thanks
No, ended up selling the vehicle shortly after.
      01-27-2023, 08:25 AM   #4
JVC
Drives: F25 X3 35i
A few other threads indicate that you need the coordinating clock spring as well to make the heated steering wheel work and then code it all.
      01-27-2023, 08:36 AM   #5
SM2
SM2's Avatar
Makes sense I do remember coming across that.
