02-22-2018, 04:39 AM | #1 |
Rep 20
Led sidelights on halogen housing
Has anyone used led w5w bulbs on halogen housing? Any recommendations would be appreciated. I have a 2014 X3 with halogen lights (without DRL), just wanted to try LED bulbs for my sidelights and use them as DRL.
02-22-2018, 09:49 AM | #2 |
Rep 287
Yes and many have swapped to leds. But you need to code for leds and disable voltage monitoring (cold and warm checks) else you'll get hyper-flashing, flickering, and dash warning.
02-22-2018, 01:11 PM | #3 | |
Rep 20
Also, I have used Philips white vision h7 bulbs as my dipped and main, would it look too strange when all lights are on? |
02-22-2018, 07:58 PM | #4 |
Rep 287
You can use jdm astar led bulbs 3030 smd led for front and rear turn signals. Same brand for brake light bulbs. Another brand are ibrightstars from Amazon site. But I found jdm astar brighter. I can't recommend headlight or tails since I have hids as standard on 35i. As for fogs standard h8 leds work.
02-23-2018, 02:47 PM | #5 | |
Rep 20
02-24-2018, 03:27 PM | #7 |
Rep 20
I've found these Philips ones, but they look like they're not canbus friendly. https://www.amazon.co.uk/Philips-127.../dp/B00OYT11RE
I've got bimmercode app, would coding out the warm and cold check, and set Led active be enough to make them work perfectly? Or do I need the resistors to hang around in the housing? Many thanks! |
02-24-2018, 06:58 PM | #8 |
Rep 287
Yes. No need to add resistors or canbus. Canbus bulbs are not 100% error free, therefore disabling voltage checks will eliminate dash errors.
02-28-2018, 02:26 AM | #9 |
Rep 20
Any idea which coding lines I would need to change? I've contacted the bimmercode Dev but he's not quite sure which coding lines represent those sidelights as every car model seems different.
03-19-2018, 06:32 PM | #11 |
Rep 20
03-19-2018, 06:43 PM | #12 | |
Boner
89
Rep 249
