03-22-2022, 08:21 AM | #1 |
Rep 1,602
[solved] Car Won't accelerate - Pedal Code P2138
Hi folks,
x3 , N55, 13' , 130 000km. This morning, the car was either NOT moving, or accelerating slooowwwwly, feels like I had 5hp. - if I start the car I can rev the engine ; no codes in cic. PEDAL give signal to engine ! - the moment I put the transmission in Drive I have the following 3 code in the cic : 1- TPMS out ( I dont have tpms, abs based tire monitoring) 2- Stability control message 3- Drivetrain issue - power limited - then the pedal does NOTHING on the engine. - engine idle fine Searched on e90post, few people were asking for the problem cause, BUT NO resolved thread . So I'm asking [Q] : what would be my best bet on that? thanks |P11EE BMW code possible causes Faulty Accelerator Pedal Accelerator Pedal harness is open or shorted Accelerator Pedal circuit poor electrical connection Faulty Accelerator Pedal Module P2138 - Throttle/Pedal Position Sensor/Switch D/E Voltage Correlation Last edited by oVeRdOsE.; 03-30-2022 at 09:00 AM.. |
03-30-2022, 09:00 AM | #2 |
Rep 1,602
scan it, erratic pedal signal, learned bmw has few revision of this pedal, bought a new one 150$, slap it, drive it.
I don't see any damage by water on my OEM pedal, but , at the end it was faulty. According to a BMW tech, this is common in a salty nordic country. |
