07-23-2022, 10:11 AM | #1 |
Rep 350
Oil leak likely from valve cover gasket
2012 N55 with around 80-85k miles on it
I've got an oil leak that I suspect is from the valve cover. The only substantial leakage occurs while driving the car. Oil ends up dripping on the catalyst and making annoying under hood smoke. I don't really see any spotting on the ground. Does my suspicion sound correct or is there a different likely cause? Assuming I'm doing a gasket replacement, any other recommended "while I'm in there" jobs? I've already done plugs and coils last November. I don't think there are any issues with the oil filter housing gasket, but I'll inspect again before ordering parts. Thanks
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project 2012 Alpine White X3 xDrive35i - My new snowmobile. 2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive. |
07-23-2022, 10:41 AM | #2 |
Rep 1,906
If you have the original serpentine belt and the belt's pulley/tensioner assembly still in place I consider changing them as a preventative maint. item to add to your shortlist (was able to change belt on my 2012 N52 motor w/o removing fan shroud or anything else, helpful to have modest sized hands!).
Good luck/Bill |
richardodn159.50 |
07-23-2022, 11:46 AM | #3 |
Rep 1,044
Those are the correct symptoms. Smoking on the right side near the converter. It's pretty easy to diagnose. Clean the area below the valve cover with Brakekleen and a cloth. Check it the next day and you should be able to pinpoint the leak. I did my valve cover on my 2012 N55 two years ago at around 80k. Youtube will show you the steps.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
Wgosma806.00 richardodn159.50 |
07-23-2022, 12:46 PM | #4 |
Rep 350
Thanks guys. Good call on the belt. Assuming the OFHG isn't having significant issues, I'll probably hold off on it until the weather cools off.
