      12-02-2017, 02:44 AM   #1
elf8888
Drives: 2012 X3 ///M sport
Any 2012 X3 28i running on Staggered set?
Please post your Staggered X3 28i photo
Thanks
      12-02-2017, 01:18 PM   #2
atarivers
Drives: 2014 X3 xDrive35i M Sport
I don't know why anyone would do it. The 19-inch run flats are expensive enough. Why add more cost with staggered sets that always lead to more frequent tire replacement? I know this because my Mercedes SLK300 can only use a staggered set. Is there some performance benefit or is it just to be different or change the vehicle's esthetics?
      12-03-2017, 06:20 AM   #3
Peter_R
Air Vice Marshall
Peter_R's Avatar
The majority of M Sport models are specified as a staggered set up in the UK. Also the wear characteristics are very similar from front to back and all my tyres wore down at a similar rate necessitating all needing replacement at the same time.
      12-03-2017, 06:25 AM   #4
Peter_R
Air Vice Marshall
Peter_R's Avatar
Thanks
What type of photographs are you looking for? It is very difficult to see unless really close up.
Side view?
From reverse of car?
      12-04-2017, 10:02 AM   #5
atarivers
Thank you, that is interesting. We don't see that recommendation in the US but it is reassuring to know doing it would not cause more frequent replacement.
      12-04-2017, 10:37 AM   #6
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
here is the 20" Wheel thread:
http://x3.xbimmers.com/forums/showthread.php?t=666241
      12-13-2017, 03:26 PM   #7
Asianoak
Asianoak's Avatar
Drives: '11 E92 M3 & "11 X3
2011 M3  [0.00]
Here is my 2011 on staggered 20s. No additional concerns with wear related to staggered tires other than the fact that the tires can't be rotated front to rear, which BMW doesn't really encourage anyway.
Instagram: @dasianoak
      12-13-2017, 08:28 PM   #8
elf8888
Nice. Thanks for sharing your f25 photos . How’s the ride on a 20s? How wide is the looks from the rear view? I ordered staggered 19s on a runflat tires. Wheels are VMR V710. It takes about a month fron cast to finish. I will post some photos once I have them installed. Tires are Michelin MXM4 245/45/19 and 275/40/19.
      12-13-2017, 09:04 PM   #9
Asianoak
Asianoak's Avatar
2011 M3  [0.00]
I ditched the run flats so ride is about the same or maybe just barely rougher. It feels smoother with less tire noise and accelerates quicker due to the lighter wheel/tire combo. Offset is perfect so wheels line up with fenders and looks more aggressive from the rear. H&Rs go on this spring to get rid of some fender gapl
      12-15-2017, 10:15 AM   #10
P1Fanatic
Drives: F25 30d M-Sport Alpine White
My UK car is staggered on 19’s. Found the rear 275s lasted 10k miles more than my fronts.
