      07-17-2017, 02:38 PM   #1
AMCross
Drives: BMW F25 3.5d MSport LCI
removing centre trim
hi there
anyone know of any video of how to remove centre trim near gear shift
need to replace our aluminium look and hand brake button
got the parts coming on there way just need some reassurance
thanks in advance
      07-19-2017, 12:50 PM   #2
VikingOne
VikingOne's Avatar
Drives: BMW G30 530e 2018
From another forum site:
Clips hold it in. Just use a plastic pry tool to pull it straight up. Don't use a screwdriver our you will almost certainly damage the trim. Start on the side of the trim, near the back where the trim meets the storage area under the center arm rest. The button module next to the shifter and the idrive controller are both secured to the underside of the console trim via screws so once you detach the trim, you will need to unplug the wiring harnesses from those modules before you can completely remove the trim.
This shows the clips:
http://www.realoem.com/bmw/enUS/show...diagId=51_8194
Previous: 2011 X3 2.0d xLine
Previous: 2015 X3 LCI 3.0d xLine
Current: 2018 530e 2L M-Sport I-Performance
      07-22-2017, 02:30 PM   #3
Lurcher
Lurcher's Avatar
Drives: 2012 z4
Some help here:
http://x3.xbimmers.com/forums/showthread.php?t=1163900
      07-27-2017, 04:43 AM   #4
AMCross
thanks guys
lurcher saw that thread but there was no pictures
managed to get it done on Saturday with no issues other than a poor bank balance for the alum trim peie and the electronic handbrake (small crack bmw fault )but still needed to pay full price
got the drivers door trim also but it looks like its secured from the inside door
so need to remove the door to replace trim
      07-27-2017, 02:00 PM   #5
Lurcher
Lurcher's Avatar
Drives: 2012 z4
Yea, photobucket changing their terms of service broke like every forum post with pics on the web.....
