      05-03-2017, 12:17 AM   #1
RL325xi
Drives: 2006 e91
opinion on a 2012 x3 35i
Going to check out a 2012 x3 35i 76k msport.
Anything I should be checking?
Also will check out a 2014 x3 35i m sport with 14k Asking $12000 more than the 2012.
are they pretty much the same? I think 35i use the same engine as 335i.
Is the Fuel pump is still issue?
Thank in advance.
      05-03-2017, 06:02 PM   #2
CalCarNut
CalCarNut's Avatar
Drives: 2015 F36 Jet Black Sport Line
Bought wife.com a 2012 X3 xdrive i28. She loves it. (hers is NA N52 6cyl..not the x35 turbo 6 N54). Check out the CPO units available and do as much due diligence on the 2 you are looking at
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint|
      05-06-2017, 11:10 PM   #3
diablow16
Drives: 2009 E92 335i 6MT
I have a 2013 x3 35i m sport with 35k and love it. I think one main change from 2012-2014 models is the 2014 has the NBT idrive. Not 100% sure on that but I remember noting that my 2013 just missed it. Not a huge deal imo but the NBT definitely looks better.
      05-07-2017, 12:58 PM   #4
JupiterBMW
Self Proclaimed Roundel Junkie
JupiterBMW's Avatar
Drives: '11 E90 M3 & '13 F25 X3
You'll see slight differences in the iDrive between the two, the '14 will have the larger iDrive controller with the Touchpad. I had a '12 X3 35i, essentially identical to the '13 I have now. I looked at a '14, it had the Tech package and therefore a slightly nicer display in the lower gauge cluster area, but otherwise, all was the same.
Go with the better buy/better vehicle, don't worry about the actual year.
Most importantly, post links to both so we can all help you compare!
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy
2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler
Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i
      05-23-2017, 08:37 AM   #5
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
Look for signs of oil leakage around the oil filter housing, the gasket is known to fail on N55s.
But you probably already made your decision...which one did you get?
