      05-10-2015, 08:24 AM   #1
sgtpeper
Drives: '16 X5d M-Sport DHP
2008 X3 Battery
Hi All,
My fiance has a 2008 X3 and the battery is dying. On my X5 I have to have the battery programmed at the dealership. Is this the case with her X3 as well or can I just swap it myself without causing a light on the dash?
Thanks for the info.
Regards,
Jeff
'19 Jaguar I-Pace First Edition
'17 Volvo XC90 T6 Inscription
'03 Porsche 996 Turbo X50
      05-10-2015, 09:34 AM   #2
Burnall4
Drives: 2009 x3
Originally Posted by sgtpeper View Post
Hi All,
Regards,
From the Bentley Manual
  • Disconnect Negative Cable First
  • Disconnect Positive Cable
  • Disconnect battery vent hose at side of battery
  • Remove hold down bolt at front of battery and lift battery out of cargo compartment
  • Clean away corrosion in and around the battery tray and on cable ends
  • When reinstalling battery, reconnect negative cable last
short answer no...
      08-23-2015, 08:00 PM   #3
Lt. Dan
Drives: 2013 X3 / 2014 335i
A new battery needs to be registered with the '08 X3 as I just replaced mine last year.
I buy my own battery, install it, then take it to an independent shop to register the battery. They should only charge you about 30 minutes in labor.
      08-23-2015, 10:13 PM   #4
ObsidianX
Drives: 2017 M2 (LBB, 6MT)
I had to have the dealer program my new battery as well. There is probably a procedure but I could not find it.
      08-24-2015, 09:05 AM   #5
bmw-again
bmw-again's Avatar
Drives: 17 440xi GC-15 X1 xline
I did not program mine and it has been in the car for over two years. I have read in a couple places it does not need it but in other places that it does. I am just going to run it until it goes out or I trade it back in. If you ask your SA I am sure they will say yes to get you in there to spend money.
