      04-08-2024, 01:27 PM   #1
Kayvoh87
Kayvoh87's Avatar
Kenya
Drives: BMW X3 F25
2014 BMW X3  [0.00]
Knock on bumpy and uneven roads
I drive a 2014 BMW X3 F25 20D and I'm experiencing knocking sounds when I drive on uneven roads. I have already replaced the wishbones and control arms on both the left and right sides, as well as the ball joints and sway bar links. I have also checked the shock absorber mountings and shock absorbers, and they seem to be fine. What could be causing this issue?
      04-08-2024, 01:34 PM   #2
pungo
pungo's Avatar
If not done so already, install the BMW 32106891974 Steering Rack Thrust Piece Repair Kit.
      04-08-2024, 01:38 PM   #3
Kayvoh87
Kayvoh87's Avatar
Kenya
Drives: BMW X3 F25
2014 BMW X3  [0.00]
[QUOTE=pungo;31056176]If not done so already, install the BMW 32106891974 Steering Rack Thrust Piece Repair Kit.
I have. It's the first thing I did.
      04-08-2024, 05:48 PM   #4
bmwPower99
Drives: bmw f25 X3 35d
Sway bar bushings.
      04-08-2024, 11:01 PM   #5
pungo
pungo's Avatar
Yet, you neglected to mention it in your initial post where you listed what you have already done
Is there anything else you already replaced that you have not mentioned?
