      08-30-2011, 08:25 PM   #1
LDNA
Drives: M3
Question about the sunroof
When the sunroof is tilt up and I try to close it with just one touch, it closes but then tilts up again. It will only stay close if I hold the close button. Is this normal? Thanks.
      08-31-2011, 11:15 AM   #2
johndeeveer
johndeeveer's Avatar
Belgium
44
Drives: X3 2007 black full option
normaly it must close with one touch, maybe there is a memorysetting active that you can reset....
John
      10-11-2011, 05:18 AM   #3
x3oiler
Drives: X3 3.0 Diesel
Search for the sunroof reset procedure - may help.
      10-11-2011, 08:27 PM   #4
LDNA
Drives: M3
just reset it. is working perfectly now. thanks!
      10-12-2011, 10:34 AM   #5
BeingWithBimmer
Drives: 2015 X1 2.8i sDrive
LDNA, where did you find the sunroof reset procedure? Can you send me a link. Thanks!
      10-12-2011, 11:36 AM   #6
Blackadder
Captain Blackadder
Blackadder's Avatar
Drives: 2009 335D
Here is the cut and paste from the post.
ALL you need to do is initialize your sunroof.
What you do is you get into your car, put your fob in the slot and turn the car ON (ie don't start it - but push the start button with your foot OFF the break/clutch)
Now, push and HOLD the sunroof button up (vent position). After about 15-20 seconds, the sunroof will vent. CONTINUE HOLDING THE BUTTON UP. After anouther couple of seconds, 15 or so (could feel long, but keep holding) , the sunroof will close, the open completely, then close completely.
Once the sunroof has closed completely, the proccess is over. It's important that you do not let go of that button while the proccess is happening.
2009 335d - Space Grey Metallic - Grey Dakota Leather
Audio control LC6i interface + base remote feeding a Boston Acoustics GT50 5 channel amp. Eclipse SC8365 + Focal 165 VRX, rear SP5010. MB Quart RSH304 12" subwoofer.
AF&AM
