05-24-2011, 09:41 PM | #1 |
Staff Sergeant
Rep 138
Run Flat Emergency Kit
I was thinking of purchasing a portable air compressor, one that will plug into one of the vehicle's power adapters along with a plug kit. My rationale is that with the temporary fix, there is less chance of damaging the wheel.
Any thoughts or recommendations? Also, is there a flash light made that can be recharged or powered off a vehicle power adapter? |
05-24-2011, 09:56 PM | #2 | |
ATAP
Rep 165
05-24-2011, 10:55 PM | #3 |
Rep 24
I picked up a very compact kit at a Super Target. It had slime (quoted as safe for tpms system) a small 12v compressor. It was very reasonable in price. It's now in the back storage compartment of my X3
05-25-2011, 01:24 AM | #4 |
Rep 1,041
I carry a small kit that includes a few fiber/rubber plugs, a tube of rubber cement, and a Slime COMP02 compressor. It works well and is one of the few low-cost, very small compressors that is reliable.
See: http://www.amazon.com/Slime-COMP02-1...6304037&sr=8-7 Slime also sells the COMP03 which includes a flashlight. Have never seen one in the flesh, so can't say if it's any good. I did publish a review of the COMP02 on Amazon.com With the BMW's built in TPMS, there is really no excuse for destroying a a fully deflated run-flat tire by driving any distance, unless you have a gigantic cut that deflates it instantly. |
05-25-2011, 08:29 AM | #6 |
Rep 1,041
05-25-2011, 05:32 PM | #8 |
Rep 120
I have one that I bought for my E90 from Wal-mart. I purchased it when I went to the regular tires. It works very well. I have just got my 28i in today. I traded my E90 in on it and I plan on keeping my pump.
05-25-2011, 06:05 PM | #9 |
Staff Sergeant
Rep 138
Has anybody used Slime? How did it work, and what was the process?
My intent is plug the tire as soon as a puncture is detected to avoid damage to the wheel and possibly get the tire repaired. |
05-25-2011, 06:29 PM | #10 |
Rep 1,876
I could be totally wrong here, but I think I decided against similar products before runflats because they said something like their use would/might make it impossible to repair the tire. Encounter that on any of the packaging?
05-25-2011, 08:20 PM | #11 |
Rep 161
Isn't the purpose of run-flats to be able to get to a tire store or dealership? Are you not supposed to be able to drive at 50 mph for 200 miles if necessary?
05-25-2011, 08:38 PM | #13 |
Staff Sergeant
Rep 138
Yes, but... At that point the tire MUST be replaced. I was hoping that by patching the tire ASAP it might be ultimately patchable
05-26-2011, 12:58 AM | #15 | |
Rep 3,855
05-26-2011, 06:57 AM | #16 |
SES
Rep 198
Drives: 335ix'09,X3'11&911TCab
Spare Tyre
If you look thru the owners manual, you will find the specs for a temporary use spare. It is in the section where wheel and tyre sizes are shown for the various models. Curious.
05-28-2011, 12:20 AM | #17 |
Rep 400
For the F25, Is the TPMS system based on wheel diameter and rotation (ABS based), or is there a sensor on the wheel?
I was told by my Dealer's parts department the slime would wreck the TPMS. So, does anybody know the real answer? |
05-28-2011, 02:37 AM | #18 | |
Rep 1,041
2011 X3s use a transmitter in each wheel for the TPMS. Previous X3's (after 2006) also use a transmitter, but the frequency was changed in 2011 so previous units will not work with the F25. Slime will damage the TPMS system and will also make the tire impossible to balance. It should not be used on a X3 unless you are planning on replacing the tire and TPMS transmitter. F25 TPMS transmitters are available from Tire Rack at $45 each. The Tire Rack units are the same as those supplied by BMW. I have (4) in my winter tires and they work fine with the TPMS. |
05-28-2011, 04:19 AM | #19 |
Rep 2,599
05-28-2011, 06:19 AM | #20 |
Rep 470
So, where would this leave a slime fixed non-runflat? Would a standard tyre also need to be replaced or could it later be patched at a tyre shop?
05-28-2011, 09:47 AM | #21 | |
Rep 1,041
Tire manufactures usually recommend that tubeless tires are repaired by using a "mushroom" plug from the inside that fills the hole and patches the area around it. No sidewall repairs are allowed. Personally, I've used rubber-coated fiber plugs installed wet, coated with fresh rubber cement on small (less then 3 mm) nail holes without a inner patch and have never had one leak or pop out. This type of repair must be done by carefully cleaning the hole with a small rattail file and using a plug installing tool, but can work and be safe. If the plug does loosen, at worse, all that will happen will be a fairly slow leak with the TMS warning of low pressure. I think an "external" plug kit and a portable compressor (Slime makes a nice one) is a much better solution then Slime, but that's just a personal opinion. |
05-28-2011, 09:55 AM | #22 |
Rep 1,041
You can put a couple of them on the roof, Paris-Dakar Rally style.
