      08-19-2013, 10:20 AM   #1
smytw
smytw's Avatar
Drives: Used to have '15 X35i
Oil Grade
Good Morning...
Do you guys think it will be ok to use my left over Mercedes Oil (Mobil1 Syn 0W-40) on my '14 X3?.. Mobil1 has BMW LONGLIFE OIL 01 approval
I bought 20qtrs at a extremely good price.. but since I have now traded my Merc for a Bimmer... not sure as BMW says I should use Castrol.
      08-19-2013, 12:57 PM   #2
bagekko
bagekko's Avatar
Drives: Lots of BMWs
2018 M4 Vert  [0.00]
2006 Z4M Roadster  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
2021 X7 40i MSport  [0.00]
The 2011 manual for the xDrive28i & 35i lists these oil grades... Approved oils belong to the viscosity grades SAE 0W-40, SAE 0W-30, SAE 5W-40 and SAE
5W-30. Assuming it is the same for newer models. Castrol is just BMW's partner. I use to use Mobil1 but have switched to LubriMoly.
But your 2014 includes 50k miles of oil changes, unless you want to change more often.
      08-19-2013, 03:26 PM   #3
smytw
smytw's Avatar
Bagekko...
Thanks for the info on the oil grades.
I change every 5K regardless of BMW recommendation.. I grew up crawling under cars and changing oil every 3K actually when Synthetic was not around yet... I guess the custom stuck with me!. True.. over kill and waste of money probably doing it every 5K. Any particular reason you switched to LubroMoly?. I used to use it on my very own first BMW.. and old '82 320i.
      08-19-2013, 04:18 PM   #4
The X Men
Drives: 2013 X3 35i
If you change your oil every 5000 miles, you can use KMart oil and it would not make any difference
      08-19-2013, 08:49 PM   #5
c3uo
Drives: 3 Series
M1 0W40 European Formula is BMW LL-01 approved and complies with BMW warranty requirements.
In fact - it is highly recommended on bobistheoilguy.com forums. I also stocked up for my X3 35i and use it between the dealership oil changes at 7500 mile intervals with a Mann Filter.
Don't forget to get an oil filter wrench assenmacher or equivalent (I got mine at bavauto).
      08-19-2013, 10:11 PM   #6
smytw
smytw's Avatar
Thanks C3UO
      08-20-2013, 09:51 AM   #7
bagekko
bagekko's Avatar
2018 M4 Vert  [0.00]
1995 540i  [0.00]
2008 BMW M5  [0.00]
2019 i3 Rex  [0.00]
I switched to LubroMoly/LiquiMoly because the M1 0w-40 was too hard to find, Walmart use to have the 5qt jug but not anymore. I use the 0w-40 TopTech 4100 in my Z3. I use the Racetech 10w-60 in my M5. The only acceptable M5 oils are the LiquiMoly RaceTech or the dealer Castrol. Both LiquiMolys I get in 5L jugs from www.bmaparts.com for a good price shipped. I've used them for all my BMW parts for 15yrs. Its just easiest to get all my stuff from one place.
I hear ya, I doubt I will wait the 15k miles for oil changes on the maint plan for my SO's CPO X3 which has 2 yrs of maint left. Will probably do at 7500 miles though.
Originally Posted by smytw View Post
Bagekko...
