      03-13-2012, 04:44 PM   #1
x3heh
Drives: Honda
Stutter
Has anyone experienced engine stutter that almost feels like a misfire on '12 28i? There is now a noticeable engine shaking from side to side just after the engine starts that lasts a minute or so while at idle and low RPM while moving (bouncy as well), then goes away. No messages on the iDrive.
Thanks.
      03-13-2012, 08:10 PM   #2
MikeBimmer
Drives: 2011 X3
If you search for idling issues or surging I think you'll find a ton on this topic. Short answer: yes!!
'11 X3 28i
      03-13-2012, 08:41 PM   #3
x3heh
Drives: Honda
I don't see many mentions of this issue for the X3, and no solutions
This is not the issue where the throtle varies widely in idle.
      03-13-2012, 09:19 PM   #4
DavC5000
Drives: 2011 Bmw X3 28i
this is just how it is when the engine is cold and its normal behavior. i think its the lifters making that noise, give it a couple mins to warm up and its gone.
      03-14-2012, 08:19 AM   #5
x3heh
Drives: Honda
There's no noise, just the vibration/shaking.
      03-14-2012, 05:05 PM   #6
MikeBimmer
Drives: 2011 X3
Watch your RPM when this is happening and you should see the needle moving. Mine does this irregularly but twice in a row this week. Last year I took it to the dealer and they CND. I don't think it's 'normal' - its a fuel injected car with electronic everything, it should compensate for cold starts like very other car I've owned. Take it in, see what they say.
'11 X3 28i
      03-14-2012, 08:30 PM   #7
x3heh
Drives: Honda
RPM is stable. I just think it will be another case of them not being able to find anything wrong with it. There's a thread on a sedan with an N52 that i've read yesterday, where a similar issue was solved by software update on an E90 I think.
Thanks.
      03-15-2012, 06:58 PM   #8
x3heh
Drives: Honda
After carefully looking at the RPM needle today, I did notice ever so slight up-and-down just south of 1000 RPM right after engine start. Is this the issue you had, or you had much more RPM fluctuation?
Thanks.
      03-15-2012, 08:34 PM   #9
bren
user
bren's Avatar
Drives: German Camaro
That sounds perfectly normal.
      03-15-2012, 09:01 PM   #10
DavC5000
yep everything so far sounds normal imo this is at startup its suppose to fluctuate a little, unless theres noises and vibrations when its at normal operating temp then i wouldnt worry.
