      07-20-2014, 07:08 PM   #1
E60orBust
Drives: "The Brothers //M-Sport" E90/2
New foglights
Upgraded the stock foglights to 2400 lumen LED 'bulbs'. Install was simple plug and play and I only used a suction cup and a knife to pop the housing out and trim the backing. No iDrive errors but I don't know if they flicker on startup yet, as I need to find a big reflective surface to test. Bought them from kbcarstuff (aka xenondepot) with a 15% coupon.
Down for Maintenance
      07-21-2014, 04:15 AM   #2
ianfp
ianfp's Avatar
Drives: X5 40D M Sport
Nice job - that looks 100 times better than the standard!
      07-21-2014, 08:13 AM   #3
LeeAC
Drives: BMW X3
I agree, those look so much better.
      07-21-2014, 09:27 AM   #4
Roundown
looks great
      07-23-2014, 08:11 AM   #5
E60orBust
Thanks everybody. This weekend I plan on getting some night shots so show the cover and spread. Night shots with a camera phone suck so I'm going to dig out my DSLR. I also have some LED reverse lights installed from Putco, but they do trigger the "Warning, backup lights out" message.
      07-23-2014, 08:44 AM   #6
nyalpine90
nyalpine90's Avatar
7425
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
why not get new oem foglights that are LED
      07-28-2014, 08:01 AM   #7
E60orBust
Actually never looked in to that since I got these on sale. Did not get a chance to take night photos, had some other things come up this weekend.
My guess is like other retrofits, you would have to do some coding of some sort to get the LED retrofit housings to work properly. These were 100% plug and play.
      07-28-2014, 08:41 AM   #8
nyalpine90
nyalpine90's Avatar
7425
2016 BMW X4  [9.33]
or it might be a simple plug n play upgrade since its standard feature on both 28i and 35i.
unless the foglight housing is different in size or in shape since it has new front design
      07-28-2014, 02:30 PM   #9
Alexi
Drives: X3
Brilliant mod! Been thinking about doing exactly the same thing as I am not a fan of the yellowish tone of the fog lights.
Need to get this done ASAP. Thanks for the inspiration, good job.
      07-28-2014, 06:57 PM   #10
E60orBust
28i and 35i might be the same housing, but this X3 is an F25 pre-LCI.
Won't be disappointed! Light output really shines
      07-29-2014, 10:33 AM   #11
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Anyone willing to try and retrofit the latest led fog light on the LCI f25 for the pre-LCI f25?
      07-29-2014, 02:01 PM   #12
ianfp
ianfp's Avatar
Mine is going in tomorrow and I will ask them if it is a straight retro-fit. If they have them in stock (doubtful), I might get them to go ahead and fit them!
I will let you know what they say!
      08-01-2014, 03:25 PM   #13
buze
Owner
Drives: G05 30d M-Sport
I'm quite interested too, the yellow fogs are quite ugly really, and I don't like having to put a big resistor in front of LEDs to prevent the warning, it's a bit silly
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
      08-06-2014, 06:45 AM   #14
ianfp
ianfp's Avatar
My BMW dealer has told me that the fog lights from the LCI will not fit. I assume that this is true, but I would like to see diagrams of both to know if a retro-fit is possible with a couple of mods!
      08-18-2014, 11:14 AM   #15
E60orBust
I didn't with these LED bulbs. Everything is self contained, you just have to trim out the back-stop since the bulb base is physically longer than a standard halogen.
      09-05-2014, 10:12 PM   #16
SoDigito
SoDigito's Avatar
Drives: 16%E2%80%99 X6 / 10%E2%80%99 5
Thanks for sharing. I'll probably try to do this mod as well. Looking forward to those night shots.
      09-08-2014, 12:23 PM   #17
E60orBust
Night shots with just the DRL's and then the fog lights on. As I post this, I just realized I can turn the DRLs (Angel eyes) off in the i-Drive
      09-08-2014, 11:49 PM   #18
SoDigito
SoDigito's Avatar
Looks very good. Thanks for the pics.
      09-09-2014, 06:54 AM   #19
pokerface
pokerface's Avatar
Drives: F25 X3 N20 / F80 ZCP
Nice upgrade! Now if only somebody could figure out how to make the inner projectors work then we'd be fantastic
      09-09-2014, 11:27 AM   #20
E60orBust
I don't think there are bulbs back there to do anything with. You could possibly do a Xenon bulb retrofit tapped directly off the battery, fuse it and put an auxiliary switch in the cabin, but I don't see any way to have it fit with OEM switches.
The forum coding guru's would have to weigh in on that I guess.
      01-02-2020, 09:47 AM   #21
3002 tii
3002 tii's Avatar
2280
Drives: Z4 M, X5, GX460
Bump I just did same mod... huge improvement. Only thing to add is I had to code off voltage monitoring using Carly to avoid the fog error malfunction.
      01-02-2020, 01:21 PM   #22
Merlin82
Drives: 2011 BMW X3 Xdrive35i
I have thought about it. But not sure I want to take apart my headlights and risk messing something up. But Im sure you could retrofit another actual projector in there.
