      01-27-2013, 12:50 PM   #1
M Crisler
2013 X3 xDrive28i, M Pkg, Space Gray with Chestnut
Drives: 2013 X3 xDrive28i
Lumbar support has no memory?
I find this really weird. I had an '06 325i with the Sport Packaga and sport seats with lumbar. When I set the lumbar in my drivers seat, it stayed in memory, much like the seat and back rest positions. In my 2013 X3, the lumbar resets when I shut the car off. I have to reset it every time I get in the car. That seems really odd to me. Why would BMW take the "memory" feature away from the lumbar? I asked my service manager and he said that the X3 is the only one that he, and the shop manager, can tell does not have a "memory". I just find that hard to believe. Can anyone tell me if they have had the same problem?
      01-27-2013, 12:56 PM   #2
noka
Drives: 2013 x35i M-Sport
Hmmm, I didn't think it reset but just stayed in the last position set manually (i.e. the lumbar setting when programming seat memory 1/2 was not recalled later from memory). Maybe I'm wrong and it goes to some 'default' position? Is that what you mean by 'reset'?
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired: '09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, '01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i,... '86 4000 CS Quattro... too many to list.
      01-27-2013, 01:54 PM   #3
M Crisler
My 325i's lumbar would stay in the last position. I set it once and never had to reset it. The X3 does not stay in the position that I set it. It goes back to what I assume is a neutral or default position.
      01-27-2013, 10:53 PM   #4
Bmwlvr60
Bmwlvr60's Avatar
Drives: BMW X3 28i
2014 BMW 528ix  [0.00]
2013 BMX X3 28i  [0.00]
2013 X3 doesn't have memory 1 and memory 2 for lumbar support, but it does stay at the same setting it was last adjusted to. It doesn't revert to a default setting when one turns the engine off.
Memory 1 and memory 2 will save separate settings for side view mirrors and up/down/forward/back for driver's seat. Can't have separate settings for lumbar or side bolsters.
2014 BMW 528ix M Sport- Space Gray Metallic, Mocha Nappa Leather, Anthracite Wood Trim. Packages: ACC, DA, DA+, Lighting, Luxury, Prem, H-K SS, SAT, Rear Shade
2013 BMW X3 28i M Sport - Deep Sea Blue Metallic, Sand Beige Nevada Leather, FS Wood Trim, HG Roof Rails, and BMW Apps. Pirelli P7 RFTs.
Packages: Cold, Con, DHP, Prem, Premium Sound, Tech
      01-28-2013, 07:40 AM   #5
RSchneider
Austria
Drives: 2011 X3 xDrive30d
Because the X3 is BMW'd value SUV that has a whole number of features not available even as option (and even though it costs EUR80k and more in Euroland). And because in principal the integration of optional electric and electronic features is lackadaisical in that vehicle.
      01-28-2013, 10:53 AM   #6
M Crisler
Hmmmm, so maybe there is an issue with mine then because it doesn't stay where I set it. The dealership says that that it is just an "X3 oversight" and that it is the only car in the line up that the lumbar support resets or defaults after the car is shut off. So you are saying that yours stays where you set it even after you turn your car off and then back on?
      01-28-2013, 01:06 PM   #7
Want the thrill
2022 X4M40i  [10.00]
My lumbar stays exactly where it was and doesn't change unless I personally change it. Sounds like something is wrong with your X.
      01-28-2013, 10:22 PM   #8
Bmwlvr60
Bmwlvr60's Avatar
Drives: BMW X3 28i
Yes.
      01-29-2013, 06:16 AM   #9
Chitown-Irish
Chitown-Irish's Avatar
Drives: 11 X3 xDrive35i
+1 Mine doesn't change either.
2011 X3 xDrive35i F25 (CPO) Space Grey/Black Leather, Packages: Premium, Cold Weather, BMW Apps, Sirius and Technology. BMW CCA Member (WindyCity Chapter). Former cars: 06 750i E65 (CPO) 07 E90 335i (bought used but had problematic iDrive so sold it to get 7-series)
      01-30-2013, 06:33 PM   #10
M Crisler
Much appreciated guys. Thanks for the feedback. I know that I wasn't crazy and that this had to be a problem, despite what my service advisor says.
      01-30-2013, 06:41 PM   #11
noka
Maybe just a software tweak/reset (but not sure why it would be different than anyone else). Perhaps there's a setting in coding.
