      10-22-2019, 08:50 AM   #1
neonmods
Drives: X3 15' MSport
LED Tail lamp issue
Hi,
I am having an issue with my rear left tail lamp, the one on the trunk.
It's actually no longer illuminated but when i remove the lamp and connect the 12 volt directly, it work.
Then i re-installed everything and work for a day or two and then shut off again.
All wiring seems good
Did someone already had that issue ?
      10-22-2019, 09:22 AM   #2
neonmods
i will try that !!
https://x3.xbimmers.com/forums/showt...t=light&page=2
      10-22-2019, 09:30 AM   #3
Commerce
Drives: 2019 X3 M40i
Originally Posted by neonmods View Post
Same issue and that thread goes over it well. Purchase a set of LED drivers off eBay, I was able to get them at $25 a piece a few years ago shipped to Canada.
      10-22-2019, 05:59 PM   #4
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Better get 4 of em
      10-29-2019, 06:18 AM   #5
neonmods
Just order 2,
30$ each Can, ship include,
Thanks for the Tip !
      10-29-2019, 07:23 AM   #6
najnad
General of the Space Forces
najnad's Avatar
Drives: 11 X3 35i M-sport
wow, I got the LED drivers for less than $10 each, but I didnt go through ebay...
      11-03-2019, 10:20 PM   #7
pungo
pungo's Avatar
Where did you source them for less than $10?
There's also an alternative LED driver, though it's not exactly plug and play but it's only $6.
https://www.ledsupply.com/blog/common-bmw-led-tail-light-fix/
      11-28-2019, 03:39 PM   #8
mjosco
Drives: 2013 X3 M
It's a really easy fix to re-solder the cold solder joint on the Chip resistor on top of LED Driver board. No cost and same issue on all 4. I did all 4 of mine in 30mins.
      11-28-2019, 04:52 PM   #9
pungo
pungo's Avatar
Great job... Could you actually see the failed soldered joint? It looks like there are several resistor chips, which one did you re-solder?
      11-30-2019, 10:15 PM   #10
drubular
Drives: 335i e90
2008 BMW 335i  [0.00]
Only $15 for plug and play OEM style ones on Amazon. I replaced two of mine last month with no issues. https://www.amazon.com/dp/B07ZNFRZHB
      12-01-2019, 07:14 AM   #11
mjosco
Drives: 2013 X3 M
You can barely see the solder fail under high magnification.
Here is a write-up that shows what chip resistor to solder. It's always the same one that has the issue:
https://www.bimmerfest.com/forums/at...6&d=1449586306
      12-01-2019, 03:07 PM   #12
pungo
pungo's Avatar
Thanks for the link to the write up. Mine haven't failed yet, but I wanted to know what to solder if I get a failure.
