      11-24-2017, 02:37 PM   #1
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Loud metallic exhaust rattle at cold start
Good morning yall
I thought I would ask the question here and see if there is an easy solution for my X3. I have noticed at cold start, I have a VERY loud metallic rattle out of the exhaust, right at the exhaust, for about 10 seconds or so. After that it goes away until the next cold start.
I am guessing there is some cold start flapper or valve maybe on the exhaust? Maybe?
Is this common and any suggestions?
Thanks!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
      01-16-2018, 10:58 PM   #2
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
No suggestions or hope on this one?
      01-18-2018, 08:09 AM   #3
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
the exhaust is probably loose, tighten the bolts
      01-18-2018, 08:28 PM   #4
frisbeeguy
Drives: BMW,Tesla, etc.
Is this common? If the car is kept outside under extreme weather conditions daily, then yes. It is a BMW after all. There is a baffle within the exhaust (it looks like a flap). On idle, the baffle is closed and when you press the accelerator, the baffle opens. This mechanism is either jammed due to crud or needs replacement. http://mixedwiki.com/bmw-x3-muffler-rattle-fix/
Also could be a loose vacuum line or bolts.
      01-18-2018, 08:38 PM   #5
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Thank you so much! I just pulled that plug and will see if that fixes it.. 5 seconds total, and if fixed, a bloody miracle!
Thank you!
      01-24-2018, 06:23 AM   #6
Mark M
Mark M's Avatar
Drives: E30M3 E83X3 E90335D
This 100 percent. I had the same thing on my 07 X3 earlier this month in the extreme cold.
      02-25-2018, 07:03 PM   #7
GCBMx3
Drives: E83 X3 2.0 D
Did you end up finding an answer for this?
      02-25-2018, 09:01 PM   #8
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Yup.. I pulled that plug which controls that flap, so now it stays permanently open, no noise.
      03-07-2018, 01:41 AM   #9
TONLOVE69
Drives: volvo
The good answer to this is.
จีคลับ
