      11-23-2017, 10:03 AM   #1
Sfkjeld
Drives: 2007 X3
Oil cooler leak
As my 2008 X3 with manual trans just hit 95k, I found an oil leak in the oil cooler area. Is this a common issue? Gasket failure?
      12-06-2017, 09:41 AM   #2
doru
doru's Avatar
Drives: e92, f25, e46, e83
It's probably oil filter housing gasket & oil cooler gasket. Easy DIY, but dealer will charge an arm & leg for it. Both gaskets are under 10 bux. There are good DIY write-ups on the 3 series forum - DIY subforum. The n/a 3 series have the same engine, so DIY applies closely. There is a coolant hose just below the OFHG that has a plastic nipple and very often it breaks off and crumbles in a million pieces. There is a seller on e-bay that sells that nipple made from aluminum together with the O-ring. Otherwise you need to order the whole hose from stealer. I changed that nipple on my daughte's e38 and my e92 with the N54 engine - same p/n and fit is perfect. When searching for the DIY, search for the aluminum nipple and you will find the e-bay seller as well.
Stable:
e92is
f25 N52
e83 N52
e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30)
      01-04-2018, 05:31 AM   #3
Sfkjeld
Drives: 2007 X3
Turned out to be both the oil cooler and filler gaskets.
