      08-12-2023, 09:52 AM   #1
bmwproblems925
Drives: BMW X3
water leak / trunk button
Hello,
I discovered that there is a water leak coming from the 3rd brake light.
Upon researching, I learned that there is no separate gasket for it so I need to replace the whole brake light.
I am thinking of applying RTV silicone around the brake light to seal it
what are your guys' thoughts on this? Rust-prone? Calling for disaster later?
https://www.permatex.com/products/ad...-sealant-3-oz/
Also, the trunk button came off.... how do I put this back? it doesn't snap back into it.
      08-12-2023, 03:16 PM   #2
littleob
Drives: BMW e36ic, 2013 x3
That button does snap in. I have taken it out a few times. Try a different angle.
      08-12-2023, 03:24 PM   #3
deyrag
Drives: x3 2.8i
I put a bead of silicone around the light when it started leaking a couple of years ago, still good. Way easier than pulling the trim to get the light off.
      08-12-2023, 06:19 PM   #4
bmwproblems925
Drives: BMW X3
Which silicone did you use?
      08-12-2023, 06:24 PM   #5
bmwproblems925
Drives: BMW X3
I will try, but why isnt this button sealed? I see electical right behind it?
      08-12-2023, 10:21 PM   #6
bmwproblems925
Drives: BMW X3
just tried, seems like the whole thing is loose.
i put my finger into the trim and felt nothing that could do the snap in
      08-13-2023, 02:30 AM   #7
bmwproblems925
Drives: BMW X3
Game Plan
Okay guys, I got a game plan, huge one.
1. Remove the third brake light, apply permatax ultra-black silicone (non-corrosive, used in gaskets in engine parts ) instead of the BS tape that only comes with the brake light with no replacement for it. OR i will take suggestions.
2. Just ordered two F25 tail light board so i can finally fix it. I just need to get 10mm socket and the thing to turn the socket. (is this right)
but I need some guidance in few parts
hand-pryed the plastic trims, that was pretty easy.
so I noticed the two things that are connected to the third brake light, seems like if I remove these two I can remove the brake light
on the left
on the right
how do I remove the thing on the right?
the left one looks like if I just wiggle it a bit and it will come off
and then IF when i successfully remove those two things connected to the third brake light
Do these just get pulled out easily from outside?
and what is this screw?, is it any of importance?
:cry
also, isnt there supposed to be like a clip on the side of this trunk switch?
ohhhhhh, I just realized its ON BACKWARDS!! ( ? )
maybe no, idk.... T^T
just checked thats not it. something is def missing. it wasn't like this.
whats this part even called?
