01-17-2021, 11:02 AM | #1 |
Rep 109
6wb install help
Hi guys just want to ask i want to install the 6wb cluster however my cluster is not yet 6wa. I was told i need a MOST connector? Can anyone help me find what the part number/s of the most connector or if i need another parts and where to install it thank you
01-17-2021, 11:17 AM | #2 |
Rep 2,551
Did you already read the 6wb retrofit guide ?
01-17-2021, 12:10 PM | #3 | |
Rep 109
Attached is the cluster that i was told that i need a "most connector" for it. But i cant find the part number and where to install it |
01-17-2021, 06:31 PM | #4 |
Rep 232
Check if your headunit have MOST output or not. If there is then all you need is to buy a most cable from eBay. If not you might have to replace your headunit.
01-19-2021, 07:59 AM | #5 |
Mr
21
Rep 103
I can see you have bkombi it doesnt have most connector. Therefore,you need both_ cable and connector.
https://www.ebay.com/itm/MOST-cable-...gAAOSwkEFdwtye https://www.aliexpress.com/item/3261...archweb201603_ |
01-19-2021, 08:01 AM | #6 |
Mr
21
Rep 103
Also, as Willywi said, if your headunit doesnt have most connector, you need to replace it for one with most connector (huentrynav or nbt headunits have most connector)
02-10-2021, 08:37 AM | #7 |
Rep 109
02-10-2021, 10:53 AM | #8 |
Rep 211
Hi scoopy, if you remove the instrument cluster it’s very easy to check, There should be green with black connector in cluster. My car is 10/2011 and I had the optic cable already installed in cluster.
Picture of connection below https://x3.xbimmers.com/forums/attac...1&d=1602247438 Link on more info from my 6WA below https://x3.xbimmers.com/forums/showthread.php?t=1765825 Last edited by e30lover318i; 02-10-2021 at 11:05 AM.. |
02-10-2021, 07:32 PM | #9 | |
Rep 109
