      10-25-2011, 05:40 PM   #1
s1948
Drives: 2011 x3 xdrive 35i
Auto Transmission
How do you put the car in neutral with no power. Is there a manual way to do it.
2011 x3
      10-25-2011, 09:57 PM   #2
Lotus7
Drives: xxxx
2011 x3
You can keep it in Neutral with the engine off, but you can't entirely shut off the whole car or lock the car when in Neutral with the engine off. In other words, if you hit the Start/Stop button a second time , the transmission will go into "Park". Also, the car will switch into Park if left unattended in Neutral for 15 minutes anyway. (no slow car washes!)
You must use "car wash" mode:
      10-25-2011, 10:06 PM   #3
Dukat
Dukat's Avatar
Drives: 2012 X3 35i
2011 x3
Good question. If your battery is dead or other electrical issue, how would you have the car towed, even brought onto a flat bed if the brakes are engaged?
2012 X3 35i | Mineral Silver | Oyster | Wave Wood
Packages | Sports | Cold Weather | Dynamic Handling | Premium | Technology | Premium Sound
      10-25-2011, 10:34 PM   #4
Lotus7
Drives: xxxx
If the battery is dead, the transmission will go into Park but the transfer case clutch will disengage. If the Parking brake (the motor operated E-brake) was on when the battery died, the brakes will remain engaged on the rear wheels ONLY. The front wheels will roll freely. The only way to move the vehicle other than dragging the rear tires is to lift the rear wheels with a "capture-type" tow rig and then to tow onto the flatbed with the car resting on the fronts. Most tow operators will just slowly slide the tires or will place dollies under the rear wheels.
I once saw an illegally parked (RWD) Lexus in downtown Chicago being dragged away by a tow truck with it's front end raised and the rear wheels on the ground. The transmission was undoubtedly in Park. The tow truck started moving, the rear tires skidded for about 50 feet and then there was a very loud "bang". Then the rear wheels began to turn. The transmission park mechanicals were certainly broken, and the owner was going to be paying lot more than just the parking and towing fine. Ouch!
      10-25-2011, 11:39 PM   #5
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
I have a problem with the fact that any damage the car incurs when being towed is the owner's responsibility. Bring the proper towing rig and do your job right, I say! Owners should be able to sue the towing companies if they bring the wrong truck and damage the car further than breaking a window to get in. There should also be required training as to how to identify if a car is front, four, or rear wheel drive.
      10-26-2011, 12:23 AM   #6
Lotus7
Drives: xxxx
Dear Judd-Pollyanna-holland,
Unfortunately, what might be expected of competent tow truck operators and what's provided are often not the same. The example I mentioned, which was dramatic enough that I can still remember small details, occurred on Jackson Blvd. just east of State. There were temporary, paper no-parking signs posted because they were going to do some overnight street patching, and the Lexus and several others were parked there anyway. The tow truck was a blue City of Chicago truck, and the driver's ONLY priority was to remove the cars as fast as possible. The driver spent all of three minutes hooking up and towing away the Lexus.
      10-26-2011, 02:18 AM   #7
Rodion
Finland
27
Drives: X3 (F25)
What is transfer case clutch? If battery is dead ( or goes dead while car is parked?) the transmission P is in fact same as N? The transmission is not locked when in P if battery dies? Ie. if you park on a steep hill without parking brakes, your car will slide down if battery dies? Oops...
Or is it so that front wheels can roll freely "in battery dead mode" even if gear is on Park. And that will not cause center differential to explode...?
I remember that if a big truck must be towed, you have to detach driveshaft from rear end in order to keep transmission in good shape.
A nice picture would do a lot of explaining... what all rolls free if gear is on P and battery dies?
      10-26-2011, 05:04 AM   #8
RSchneider
Austria
Drives: 2011 X3 xDrive30d
Not too uncommon contempt of the public sector for private property, hm?
Over here and in Moscow, where I spent my last couple of years, they use only flatbed trucks with cranes. They are more careful, but they still dent and scratch cars.
      10-26-2011, 07:40 AM   #9
Lotus7
Drives: xxxx
TCC: There is an electronically operated clutch in the transfer case that controls the amount of torque that goes to the front wheels. It can be set to "couple" power to the front drive-shaft at anything between 0% and 100% of available torque while the vehicle is running. If the rear wheels begin to slip, the transfer case clutch torque setting is increased and more torque is sent to the front wheels (reducing the torque at the rear and stopping the rear slippage). If the transfer case clutch is engaged, the front wheels cannot "freewheel". No battery = no electronics = no TCC = front wheels free to roll.
Park Mode: Although the transmission selector "Park" mode "brakes" the rear wheels, it is not actually a brake. Pressing the "Park" button on the gearshift lever OR shutting off all vehicle power engages a mechanical park "pawl". The "pawl" is a metal pin that drops into a gearwheel connected to the transmission output shaft (which is always connected to the rear driveshaft) that prevents it from turning. The park "pawl" will engage automatically when no power is applied. Ignition COMPLETELY off (second button press) OR dead battery= transmission locked = rear wheels locked. It's just like a older car with a mechanical park position on the gearshift, it will stay in park. When parked on a hill, the E-Brake should be used to hold the vehicle (and the front wheels turned to the curb), not just the transmission "Park' mode which will stress the transmission if used alone.
E-Brake: The Electronic "Emergency Brake", operated by the "pull/push" switch on the console behind the gearshift lever (often called the "Parking Brake") actually is a real braking system. When the E-Brake switch is actuated, a powerful electric motor operates mechanically to pull two metal cables that are coupled to the rear wheel brake calipers. The brake pads are engaged mechanically through the calipers. You can feel the brake pedal drop as the cables reduce hydraulic pressure in the rear calipers by mechanically pressing the pads. The motor is used to engage the E-Brake cables and is used again to dis-engage them. If the Brake Hold is on (green light), the E-Brake (red light) will automatically engage when the car ignition is shut off. The rear-only E-brake will remain in whichever state it was in when the power was removed. A dead battery will not apply the E-Brake if it was previously off, but without battery power, the E-Brake will not operate either. E-Brake only can lock the rear wheels.
Because of the transfer case clutch, the center differential will not explode if the vehicle is moved a short distance (enough to get it onto a flat bed truck) with the rear wheels elevated at low speed. It's effectively disconnecting the front drive-shaft, but not the rear drive-shaft. Even if the vehicle is in "Park" the front wheels are free to rotate (but NOT the rears). However, if the rear wheels rotate when in "park" (transmission park mode - not E-Brake "Park") the transmission will be likely be damaged.
In Neutral the park pawl is disengaged and the vehicle can roll with no damage, but ONLY if the ignition is on, ONLY if the E-Brake is off, and ONLY if there is battery power.
Sorry it's so complicated, but BMW designed it, not me.
      10-26-2011, 10:36 AM   #10
Rodion
Finland
27
Drives: X3 (F25)
Thanks Lotus. It is not complicated and you described it well, at least in my point of view.
One thing only: if towed longer time "rear up" and front wheels rotating free on the ground (sort of one axle trailer style), can it do harm to center differential even though the TCC is disengaged? Maybe oil heating issues or something like that?
And boy, am I now glad I ordered with manual stick! Hard to imagine that automatic electrocomic transmission working well for five years in here
      10-26-2011, 11:25 PM   #11
xDrive35i
xDrive35i's Avatar
It's a shame. The law should under no circumstances dictate a, say $7000 repair cost just because a car is illegally parked. Imagine if you had gotten stuck on Lake Shore Dr. in the blizzard last February. Wouldn't you have wanted the operator to pay close attention to making sure your car is returned to you undamaged?
Weeks before I was supposed to give up my 535 wagon end-lease back in December, I was involved in an accident. A woman stopped in the left lane on Lake Shore Dr. around the blind curve near North Ave. to CLEAN HER WINDOWS (because somehow the electric-ness of her Land Rover's windows never occurred to her). Long story short, one guy hit her, the next guy hit that guy, and I had no time to react after coming around the bend, so I collided with cars two and three, skidding between them and the barrier. I thought the car was effectively totaled. The front axle had snapped, the steering rack was finished, and there was significant body damage. The police, in their ignorance to the $70,000 station wagon with Four Wheel Drive that had just incurred damage equal to half its residual value, called not a flatbed to take it off Lake Shore Dr., but a typical, two-wheel fastener crane tow truck. I stared at it as the tow truck took it away down the exit ramp, listening to the rear wheels skidding across the pavement, and then I heard an echoey "clunk," followed by a nails-on-chalkboard whine. My beloved wagon was finished. And maybe, had more attention been paid to the kind of drivetrain on the car, it might not have been totaled, and Ms. Window Washer wouldn't have incurred over $40,000 in damages. She lost her insurance anyways. All's well that ends well, I guess.
      10-26-2011, 11:44 PM   #12
Lotus7
Drives: xxxx
I'm Jealous! No manual transmissions allowed on F25s in the US.
I guess the German engineers suspect that American's won't know what to do with the third pedal. Our X3 is the first automatic we've had in the family in decades. So far, it's a fine transmission. (fingers crossed)
Don't know if your use of "electrocomic" was a typo or a "Freudian slip". Either way it's very funny!
There is a small amount of fluid in the TCC, and with only some of the parts turning it might not lubricate everything properly, so one would definitely NOT want to want to tow the X3 any distance or at even moderate speeds that way.
      10-27-2011, 02:25 AM   #13
Rodion
Finland
27
Drives: X3 (F25)
Ok, good to know.
I used electrocomic on purpose. But I didn't know it has some actual meanings as well. We use that in Finnish sometimes when we mean electric device that we want to make fun of.
      10-27-2011, 07:57 AM   #14
Lotus7
Drives: xxxx
Ok, good to know.
Love it! Going to add it to my vocabulary and spell checker since the whole world is becoming "electrocomic". Thanks.
      10-27-2011, 12:55 PM   #15
s1948
That is what I was thinking when i wrote the original question. Since then I have spoken to the shop foreman at the dealer and this years model x3 has no manual way of putting the transmission into neutral without removing the panels under the transmission and turning a lever. He did point out that tow truck drivers can put enough electricity into a completely dead battery to get it into car wash mode so it can be put onto the flat bed. It can be done from both ends of the car - Like jumping it.
He also stated they will all be that way soon. The current x5's still have the lever under the cup holder but that will change as well.
Hope this helps.
      10-27-2011, 01:17 PM   #16
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
It's a shame. The law should under no circumstances dictate a, say $7000 repair cost just because a car is illegally parked. .
Completely agree. Eventually, someone will sue a municipality for this and win big. To my knowledge there is no public law that says 'if you park illegally, we have the right to do whatever degree of damage to your vehicle we deem necessary'.
Of course, then there are those stories of cars parked in front of a hydrant and the fire trucks literally shoving them out of the way... and I'm okay with that.
I think it is bad luck to be superstitious
      10-27-2011, 03:28 PM   #17
Lotus7
Drives: xxxx
LEDZEP, Was this one of yours?
Don't know about the rest of the world, but over here, they just break the windows and then fill the car with water.
      10-27-2011, 08:53 PM   #18
Want the thrill
2022 X4M40i  [10.00]
This happened to somebody on the "other" forum. Makes for an interesting read:
http://www.bimmerfest.com/forums/sho...606&highlight=
      10-27-2011, 10:32 PM   #19
Penso di no
lapsed
Penso di no's Avatar
Drives: Yes
The festies don't appear to have figured out car wash mode, though.
