      04-17-2014, 12:33 PM   #1
kwcbimmer
Drives: 2014 X3 28i
Connect hard drive to USB?
I currently have all my music on a 8G flash drive. however, it's running out of storage now. So I'd like to use my spare 500G portable hard disk, but am concerned if it will risk draining the battery? anyone has experience connecting a hard disk to the USB in X3? Thanks
      04-17-2014, 01:31 PM   #2
flavius
Drives: 2019 440i Gran Coupe
I assume your X3 does not have a hard disk, then. I have never used a typical external HD with the car - but I did use a 64 GB USB stick and that was working fine.
-Experienced driver; cocomats
      04-17-2014, 01:34 PM   #3
Mingstar88
Drives: BMW X3 35i
there's only so much power going to the usb port, i wouldn't worry about. i assume you'll be using 2.5" hard drive. when the car is off, hard drive will stop spinning.
      04-21-2014, 02:51 AM   #4
Rogerbu
Drives: X3 GO1 30e M Sport
Use a 'Y' shaped USB cable. 1st USB connector to USB Port under the phone cradle and the 2nd 'flying' USB connector into the power socket to pick up 12V.
As above, all power drain stops 15 mins after stopping. I don't believe the 2.5inch disk is spinning until you access the US port, but I may be wrong.
Roger
      04-21-2014, 04:31 PM   #5
Bustofa
Drives: F25 X3 XDrive20D SE
I've had no issues in two and a half years! Just stick it in, it'll be fine.
      04-22-2014, 01:20 PM   #6
kwcbimmer
Drives: 2014 X3 28i
Thanks guys. I'll move all my music to the hard drive and connect it.
