      01-25-2021, 10:54 PM   #1
arkow
Drives: 2012 X3 35i, 2019 M2 Comp
harsh downshift when coming to a stop
I recently noticed that my 2012 X3 35i with 111,000 miles is having harsh downshift when coming to a stop, im thinking it's from 2nd to 1st gear. Other than that it's smooth as butter. recently I had transmission fluid done, but even before that it was doing the same thing. I had a leak, hence the reason I had it fixed. Any ideas what could be causing it?
      01-26-2021, 12:13 AM   #2
Bdavi011
Drives: 2013 BMW X3 3.5i
My personal take would be to reset transfer case and transmission adaptations. Also, change transfer case fluid incase you haven't. (Unless you dont have one)
      01-26-2021, 08:47 AM   #3
e30lover318i
Drives: E30,E34T,E46,F48
I was having the exact same issue. I was also have issue with 1st - 3rd in traffic. Almost as if the transmission wasn’t sure what gear to choose. I did a throttle adaptation reset and the problem completely disappeared
Info below
https://f10.5post.com/forums/showthread.php?t=455949
      01-26-2021, 09:22 AM   #4
383vett
383vett's Avatar
This happened to my daughter's 2013 328i. She said it felt like a very harsh downshift when coming to a stop; almost like she was rear ended. The car was under a CPO warranty at the time and a code was brought up referencing a transmission accumulator valve issue. It was replaced and the car was fine.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      01-26-2021, 12:45 PM   #5
arkow
I'll try the reset tonight, thank you
      01-26-2021, 01:09 PM   #6
e30lover318i
Arkow drive it for a day or 2 after the rest it still might shift a little funny till it learns your driving style
      01-26-2021, 02:23 PM   #7
arkow
sounds good, thank you
      02-01-2021, 04:03 PM   #8
arkow
I reset adaptation but I still feel the harsh downshift when coming to a stop or slowing down, its during 3rd gear to 2nd gear when it feels like someone hit you from behind..everything else is fine..any other ideas?
      02-01-2021, 05:42 PM   #9
383vett
383vett's Avatar
See post #4 above. Same transmission.
2021 SQ5
      02-02-2021, 10:21 AM   #10
arkow
dang it, I don't have warranty anymore, I guess I need to take it in to have the dealer scan for codes and see what is going on. I love the car but Tesla is really catching my eye lately, I see they everywhere here in Phoenix, plus have few friends that got it and they love it...decisions decisions..
      02-03-2021, 10:30 AM   #11
supernova1
Drives: 2013 X3 x28i
Try using one of the BMW scan tools and read transmission adaptation values. Plenty of posts show the acceptable values. Check if any of those A,B,C,D,E values is really out of range - this will point to particular clutch issue.
I check those for my car about once a month to see their change dynamics - this may point to onset of transmission issues.
