      01-22-2021, 06:29 PM   #1
lawdude
lawdude's Avatar
Drives: 335i ZPP ZSP TiAg MT
2017 xDrive 35i Sensor Problem
Today the right front sensor decided to activate every time vehicle came to a stop. I cleaned all sensors, but the problem persists. Anyone run into this problem?
What do I know? I'm insane.
      01-22-2021, 09:32 PM   #2
e30lover318i
Drives: E30,E34T,E46,F48
Wheel speed sensor? Speed sensors are magnetic they don’t last forever. You could have a defective sensor or tone ring
      01-23-2021, 12:11 AM   #3
lawdude
lawdude's Avatar
Sorry, its the proximity sensor.
      01-23-2021, 10:45 AM   #4
lawdude
lawdude's Avatar
No trouble codes. No notifications. As a matter of fact, I took it for a short ride this morning to video the problem. You guessed it. Problem did not manifest. Dank Farrik!
I have an appointment for February 9 with the service department just in case.
Does anyone know how to keep the proximity sensors from beeping?
      01-26-2021, 04:10 PM   #5
E36M3
Drives: 97 M3, '14 335i, '12 X3 35i
Mine took a rock to one of the sensors just like those gravel pieces that chip windshields. I bought a replacement and changed it myself. Been working perfect since then. Suggest you look for similar type of damage and if not check the codes through ISTA-D to see what it flags on your system.
      01-30-2021, 03:53 AM   #6
lawdude
lawdude's Avatar
Thank you E36M3. By the next morning the problem went away and hasn't returned. This is my second BMW. First one also had a weird problem or two along the way that seemed to resolve on its own.
      02-09-2021, 09:00 PM   #7
ClampThurst
Drives: 2018 M4-Silverstone, 2017 X3
Mine started acting up because it came unglued and fell inside the bumper. Is your sensor firmly glued or has it come loose?
      02-13-2021, 07:54 PM   #8
lawdude
lawdude's Avatar
Nothing seems loose. It actually did it again a couple of days ago. Both times it happened it was parked in the rain. I saw a "quick fix" for it on YouTube. The problem seems to be moisture. My wife came home and told me it again and I applied the quick fix, which seemed to work. Squirt a healthy dose of WD40 directly onto the sensors and wipe it off. That took care of the problem immediately.
