05-23-2020, 06:47 PM | #1 |
Rep 14
Water enter 2014 BMW X3 battery compartment when driving in rain
Hi everyone,
I experienced a weird situation of water in battery compartment in my 14 X3. Here is what happened, initially I noticed water because liftgate stopped working and there was about half inch of water in the battery compartment and the liftgate control module was damaged by water. But I don't see water mark on both sides of the battery compartment. So I close everything and use garden hose to spray water to the car from top to bottom, no water entered. Then after two days of rain, no water enter as well. Finally I decided to drive in the rain (13 miles) to see what happen and water enter the battery compartment but both sides were dry. Does anyone experience this before or does anyone know where the entrance may be? Thanks and be safe. |
05-24-2020, 06:57 AM | #2 |
Sandy
Rep 29
Could it be due to water from the sunroof drains?
I know there is a history of these drains letting water into the car. Lots of info on YouTube how to check the drains and fix them. good luck |
05-24-2020, 07:35 AM | #3 |
Rep 14
Thank you Sandy5454, I know what you are talking. But usually these drains clog will let water into the side, not in the middle directly. I will check it out for sure.
06-03-2020, 03:40 PM | #5 |
Rep 170
With my wife's X3, water was seeping in from the 3rd brake light (CHMSL - center high mount stop light)
The Black Prinz | 09E82N51 | BMW 3-Stage Intake Manifold | BILSTEIN B12 Pro-System+ | ///M Control Arms | ///M Bushing kit | ///M Strut Brace | DINAN Camber Plates & Rear Shock Mounts | ECS Performance Trailing Arms | aFe Magnum Force Intake System [Dynamic Air Scoops+Stage 2 CAI] | BMW Performance Exhaust | BMW Performance Brakes | GOODRIDGE G-Stop SS | DEPO V2 | Style 220M reps |
06-03-2020, 03:47 PM | #6 |
Rep 14
In your case, where the water will accumulate considering the light is pretty high, still in battery compartment? Today after a big thunderstorm, still no water sign in the battery compartment, in my case, I have to drive in the rain for water to get in which is so weird
06-03-2020, 04:47 PM | #7 | |
Rep 4,335
tracer bullet2413.00 |
06-04-2020, 10:15 AM | #8 | |
Rep 14
06-04-2020, 10:37 AM | #9 |
Rep 4,335
You're welcome. Another but less desirable idea would be to have someone under the car with a water hose set to a somewhat forceful spray pattern thereby imitating a drive in the rain while you are in the battery compartment looking to see where its coming in from. Maybe you can ask one of the neighbors you don't especially like to lay under the car with the hose
06-04-2020, 02:09 PM | #10 | |
Rep 170
Shop found the leak and sealed with silicone & no water issues since.
06-04-2020, 07:49 PM | #11 |
General of the Space Forces
171
Rep 721
I had a similar issue...water on cargo cover and some below, but never got bad enough/I caught it in time before it got down to the battery (I think). I had been rear ended and repaired, so I took it back to the shop thinking they messed something up (long story, bad auto body shop, was like pulling teeth to get things done right)...they said it was the 3rd brake light and replaced it. I also adjusted the bump stops down a bit. Since both of those, no water in the back.
06-04-2020, 09:51 PM | #12 | |
Rep 4,335
afrirado , you getting all this? Possibly the test to do is make sure your cargo cover is fully extended and locked into position, place a dry towel over it and then spray water up at the third brake light for a few minutes and then see if your towel is wet. Not sure how long it might take before the water makes its way through and onto your towel but its a pretty easy thing to do and if this is in fact the entry point, you would be able to follow the water trail back up to see where its coming from. Could be the light sense is cracked or the gasket is dried up. . |
06-04-2020, 10:24 PM | #13 |
Rep 14
I did try to spray water with garden hose from top to bottom and even from under the car, but no water get into battery compartment. In recent days, there is thunderstorm everyday and I did not see water get in, the cargo mat or cover are always dry. it's heavy rain now and will check first thing tomorrow morning.
06-04-2020, 10:57 PM | #14 |
Rep 2,547
For difficult water leaks, I've heard of shops using some type of fog/smoke machine in the vehicle and see where it comes out. Know someone in a band
