03-13-2020, 05:39 PM | #1 |
Rep 18
Trying to Figure Out Oil Leak (Pics)
Hi All,
First post on here, but have been a lurker for years. I registered because I'm having trouble identifying an oil leak on my X3. There is a small amount of oil on the driveway every day, it is generally yellow in color and smells "oily" (if that makes sense). My first thought would be brake fluid, but the reservoir is perfectly just below "max." Given the fact that there's no dipstick, I used iDrive to check the engine oil and it came back 100 percent full. No lights are on, the car performs perfectly and if not for having a white concrete driveway, I would never have known anything was leaking. The oil dripping appears near the driver's side to the rear of the front tire. The only thing I could find under the hood was a small amount of oil on the right side (driver's side) of the engine cowling near a cap. But it was just a drop or two. I also can't figure out from *any* diagram what, exactly, is inside this cap. I tried to loosen by hand and it will not budge. Didn't want to break out tools and force it without knowing what it is, much less if it's even the problem to begin with. I'll leave two pics below. My guess is a filter given torque measurements, but I'll leave it for the masses to advise, lol. Thanks for any help! Last edited by TurboDan737; 03-13-2020 at 05:52 PM.. |
03-13-2020, 05:54 PM | #2 |
Rep 1,044
The oil filter hosing gasket has been known to leak on X3s.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
03-13-2020, 06:43 PM | #3 | |
Rep 4,361
03-14-2020, 09:06 PM | #4 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
On ALL N55s. ETA for leaks is 75K miles on average, it seems.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
03-14-2020, 09:55 PM | #5 |
Rep 4,361
03-15-2020, 04:51 PM | #6 | |
Rep 2,551
That round cap you are showing is the oil filter cover. The Oil filter is right under it. You need a special oil filter cap socket to remove it properly. If it's wet, the the o-ring on the cap may not have been installed correctly. Take the cap off with the special tool and check the o-ring. |
03-23-2020, 04:34 PM | #7 |
Rep 80
That could just be oil from an oil change. When you remove the filter oil spill everywhere unless you open it partially to break the vacuum and let it drain for a while. First degrease and clean the area very thoroughly and then monitor if it comes back before changing anything.
03-23-2020, 07:59 PM | #8 |
Rep 396
Drives: 2022 X4MC - Marina Bay Blue
That is exactly where you will find oil from a failing oil filter housing gasket. Clean it up and check in a couple of days. If it is back, get that fixed. Long term, oil will disintegrate the rubber on the drive belt and believe it or not, the engine can "inhale" it (literally suck it in to internals) and worst case, then your engine is toast.
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup). Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport |
03-24-2020, 06:01 PM | #9 |
Rep 470
