      02-06-2024, 01:53 AM   #1
pabloaguas
Drives: 2014 X3 35i
Replacing coolant hoses without replacing...
Has anyone here replaced the following coolant hoses without buying the aluminum part they attach to:
The upper and lower turbocharger hoses
Pipe to water pump hose
Would like to replace these hoses without replacing the aluminum parts. Would cost $300 to replace about $30 in hoses. I'm thinking to remove them and figure out what hose size and just replace the hose. Has anyone done this?
https://www.fcpeuro.com/products/bmw...er-11537583901
https://www.fcpeuro.com/products/bmw...er-11537583903
https://www.fcpeuro.com/products/bmw...x3-11537617502
      02-06-2024, 06:50 AM   #2
Weslsew
Drives: F25 X3 35i
Those are probably only sold as an assembly. Haven't done it but I don't see why you couldn't go to your auto parts store and browse through what they have and see if you can find something that will work. I think Napa does or used to make custom hoses, a shop that does a/c work can probably also replace the rubber parts only for you if you don't want to do it yourself
