12-31-2019, 03:33 AM | #1 |
Rep 586
Bunch of fault codes
I decided to start working on my X3 since free maints are done. First time pull codes with Rheingold and came up with this bunch of error codes. The ones related to drive train and mainboard got me really nervous.
Wondering if anyone encountered similar fault codes and how to get them resolved. my X3 is N20 xDrive with 36k miles on clock. thanks |
12-31-2019, 09:32 AM | #2 |
Rep 2,908
I assume your car runs correctly and has no issues? Weird that some are recorded at mileage your car has not reached yet. But assuming the car is fine, there is nothing to resolve. Click on that clear fault memory button at the bottom of the screen. They probably will not return.
12-31-2019, 10:18 AM | #3 |
Rep 540
Drives: 2016 BMW X3 35i M-Sport
You can scan a brand new car and find faults. Almost normal. If the car doesn't seem broken don't get to worried about them.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
12-31-2019, 11:41 AM | #4 |
Rep 22
I bought my 2016 X3 last year from a dealership and the first time I went to an indy he told me about a bunch of codes when he scanned. He thought it was weird but cleared them and don't expect them to come back.
I did do module updates using esys and also bimmercode coding and I feel like maybe this triggers some faults that are not cleared up. |
12-31-2019, 01:09 PM | #5 | |
Rep 586
I kind of have a feeling the low voltage ones might be due to frequent stop-start at traffic lights. Gonna erase them and see if the 3 reappear. |
12-31-2019, 01:14 PM | #6 | ||
Rep 586
12-31-2019, 09:55 PM | #7 |
Rep 51
That's definitely odd. My advice would be to take pictures of all faults, see which ones are active, then clear the error memory on the entire car. From there see which ones come back then go from there.
By glancing at the codes it seems that many of those issues are spread out around the car and not in one central place which makes me wonder if they are all connected to the same module and that the module might be going bad...possibly due to water intrusion perhaps? Again, I'm just speculating but for your car only having 36K miles I couldn't imagine all of those codes are legit...start process and elimination and go from there...hope this helps. |
01-01-2020, 07:14 PM | #8 |
Rep 22
Same... except I couldn't live with the idea of not running the latest software in all the internal modules. Déformation professionnelle. As for coding with bimmercode it's basically only flipping switches in configuration files so it's pretty safe.
01-07-2020, 03:15 PM | #9 | |
Rep 4,337
If you have a dash cam or anything else that might be running while the car is off, that will drain it. When not driving mine, I always keep it on a battery tender. My battery is 9 yrs old and in good shape, I've had batteries last 14 yrs this way :-) If you battery is marginal, it will cause all sorts of weird but meaningless codes to be thrown. Anyway, just a thought. |
01-07-2020, 03:43 PM | #10 | ||||
Rep 586
I also wonder if it happens at start-stop at traffic light. The millage occurred is in the middle of a trip. |
01-07-2020, 04:22 PM | #11 | |
Rep 4,337
I just measured my 9 yr old battery...12.52 volts with engine off and 12.9 with it on. I have no clue if I have any faults in the system because the car performs as expected so I have never looked :-) |
