11-02-2019, 06:07 PM | #1 |
Rep 3
2017 X3 weird problem replacing halogen to LED
Greetings everyone!
I am new to the forum and this is my first post. I have a weird problem after replacing the halogen DRL with LED on my 2017 X3 and i hope someone can help me figure out what's going on. i got the warning message after replacing the halogen DRL with LED, i know this might happen with some LEDs, so i removed the LED and put the halogen bulb back. However, the weird thing is, the halogen bulb won't light up, and i still have that warning message. It feels like something cut the power of that bulb, is this even possible? or may be the fuse is blown ? what can i do? And, could someone recommend a W21W LED that does not have the warning message? Thanks. |
11-03-2019, 12:05 PM | #2 |
Rep 3
UPDATE:
The problem is solved. I was trying to identify where the problem is, so i swapped the driver side and passenger side halogen bulb, now both DRL bulb light up and the warning message is gone. But the whole situation is very confusing, and i still don't know what happened. now back to where i started, could anyone recommend a LED that does not have warning message? |
11-03-2019, 01:12 PM | #3 | |
Rep 2,036
You will need to code out the warnings with either a laptop and Esys or with a smartphone and BimmerCode app.
11-04-2019, 05:34 PM | #4 | |
Rep 56
01-05-2020, 03:20 PM | #6 |
Rep 1,906
Does not appear to me BimmerCode will do what you require; these are the options available in one of two menus related to daytime driving lights; the other menu enables one to set light output intensity as % of full scale value.
I recall in swapping in LEDs in place of original halogen backup bulbs I needed to code off the warm/cold checking functions to insure proper operation, and there was a selection of bulb type (halogen, LED) as I recall. I don't see those options available for headlamps. Hope this makes sense/helps,m |
01-05-2020, 03:44 PM | #7 |
Rep 56
