      02-01-2018, 02:58 AM   #1
Marekw
Drives: BMW X3 F25
F25 coding bulbs to LED
Hello,
Can someone share code list (cheat codes) to disable hot and cold check for rear fog and revers bulbs?
I'm attaching coding of bulbs I coded successfully...
Thank you
      02-01-2018, 12:08 PM   #2
VikingOne
VikingOne's Avatar
Drives: BMW G30 530e 2018
I used the attached on my 2015 LCI X3
Previous: 2011 X3 2.0d xLine
Previous: 2015 X3 LCI 3.0d xLine
Current: 2018 530e 2L M-Sport I-Performance
      02-02-2018, 01:22 AM   #3
Marekw
Drives: BMW X3 F25
perfect, I will give it try, thanks a lot....
      02-04-2018, 10:39 AM   #4
jimmydick
Boner
jimmydick's Avatar
Drives: 18 AW ZCP
I've looked all over for this. Thanks.
      01-05-2020, 01:12 PM   #5
Tgsmith4845
Drives: 2013 BMW X5 xDrive50i
Hi all,
2016 X3. I replaced the standard daytime running lights with LEDs and am now getting an alert. Does anyone know which code I need to change for drl’s? I’ve disabled the codes for the front low and high beams but cannot find the code for drl’s.
Thanks
      01-05-2020, 07:47 PM   #6
littleob
Drives: BMW e36ic, 2013 x3
easy coding
I have just used bimmercode to recode all the led bulbs it's quick and very easy. coded the windows rear hatch and moon roof to close with the remote. depending on your car there are 100 changes you can make from lights to how hot you want your seats warmers. well worth the money. about 35 for the app and 65 for the bluetooth obd11 plug
      01-05-2020, 11:19 PM   #7
robertpwsm
Drives: BMW X3 F25/N47
LED Coding
Originally Posted by Marekw View Post
Hello,
Thank you
Awesome info! Thanks!
