      03-08-2012, 06:13 PM   #1
Beyu
Drives: 135i
Pathway Lighting Key Fob
Hey all, I just discovered today that you can activate pathway lighting by using the key fob.
For those who don't know, you can activate it by quickly pushing the diamond shaped button and this will turn on the headlights, tail lights, and door handle lights. This works regardless of what setting you have the headlamps set to, just make sure not to hold down the button for too long or else the alarm will go off.
      03-08-2012, 06:17 PM   #2
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
You can also long press it to panic alarm the car
      03-09-2012, 07:57 PM   #3
roundtree
roundtree's Avatar
Drives: '12 F25 28i SB
2013 BMW 328i  [10.00]
2012 BMW X3  [10.00]
Originally Posted by Beyu View Post
...just make sure not to hold down the button for too long or else the alarm will go off.
Anyone else hear an echo?
      03-10-2012, 03:56 AM   #4
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
53
Drives: Like a Demon!
2010 BMW Z4 35is  [10.00]
2013 BMW X5 30d  [0.00]
Not only that. But in an emergency you can follow the row of lights on the floor to your nearest exit. As you are not guaranteed to sit in the same seat, An easy way to remember is to count the number of rows between your seat and the nearest exit.
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      03-11-2012, 06:46 AM   #5
Nahoa
Not sure, but ya wanna be careful holding that diamond button . . .
      03-13-2012, 12:31 PM   #6
hekki
Drives: Bentayga, GT3 RS
Does X3 without keyless entry have diamond shaped button? Also if you press that button, does it work when you are entering your car and how long they will be on if you leave the car and press that button?
      03-16-2012, 08:31 AM   #7
saulgoodman
saulgoodman's Avatar
Drives: 2012 F25 N52T
2015 BMW 328XI  [0.00]
+1
even my key fob doesn't have any diamond shaped button. It has unlock, logo/lock, tailgate open and speaker/light symbol button...I have Comfort access keyless entry.
      03-17-2012, 05:41 PM   #8
Beyu
Drives: 135i
I don't have keyless entry either. The button I'm refering to is the same button as the car alarm/imobilizer which is below the tailgate button.
Yes, the button works whether you are entering or leaving your car, all it does is turn on all of the exterior lights, it doesn't lock or unlock the car.
The duration of the lights depends on the "pathway lighting" setting under the lighting menu in iDrive.
