      09-25-2011, 11:05 AM   #1
GBimmer
Drives: 2011 BMW x3/2008 Mercedes c300
need help on 2011 bmw x3 mods
I just got a 2011 BMW X3 deep sea blue 28i couple of months ago and I didn't get the xenon headlights. Does anybody know where can I get them or can I get the angel eye rings installed? Also for the front headlights does anybody know where I can get a clear side marker instead of the orange one that the X3 comes with? You can view it in the pic. And finally can the 28i fit 20inch wheels? Or are the brakes to small for it? I would appreciate all the help.
      09-25-2011, 07:30 PM   #2
dandanio
The one that drives!
dandanio's Avatar
Drives: 11 x3 35i/09 Jetta TDI
You can get them installed at the dealership. Granted, probably not all dealerships would do such a job, and the ones you find that would, will charge an arm and a leg for it.
Go to realoem.com, select euro-spec X3 with xenons and check the part numbers for the headlights. Those won't have any of the orange sidemarkers, that are MANDATORY in the US. Make sure you know what you are doing as your car might not pass inspection.
As long as the 20s are within the spec offset-wise and are load-rated for an x3, you should be good. Just make sure your tires circumference is +- a few percent.
      09-25-2011, 08:49 PM   #3
GBimmer
Thanks bro for the help, I'm going to look into it. Thank you.
      09-25-2011, 10:17 PM   #4
ivanoski
F25 X3 2.0 Diesel
ivanoski's Avatar
Drives: 2012 BMW x3 20d 8SpdAUTO BLACK
thats why i got the xenons, i really wanted those angel eyes
