      03-16-2014, 11:11 AM   #1
Longbow64
_______
Longbow64's Avatar
169
Drives: 15 M3, 13 X3 35i MSport
Carbon Fiber gear selector trim
Ordered the carbon fiber gear selector trim from Stealth Auto. It's carbon fiber 2x2 pattern with clear coat with the same pattern direction as other BMW carbon fiber products (top right to bottom left). This one is $110 vs the BMW M Performance one that ranges from $160-200. The M performance one is a dry carbon that kind of looks like the carbon leather from the E90 M3. The M Performance one comes with a new middle plastic piece with an ///M logo on it. The Stealth Auto one requires you to reuse the old one. I chose the Stealth Auto one because I like the gloss look and price. It actually goes well with the cf wrap.
Install is pretty easy. Use a small flat tip screwdriver to remove the center plastic piece. Don't worry about the Park button. The center plastic piece is on there with adhesive. I was able to remove it without heating it up. Once it's removed, remove the T10 screw and everything will come apart. Set the park button back in place, put the new carbon trim on. Screw the screw and little white plastic piece connected to it back in. Use rubber cement or trim adhesive to reapply the center plastic piece.
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat
      03-16-2014, 11:15 AM   #2
Longbow64
_______
Longbow64's Avatar
169
Another shot
Here's a link to the M Performance version from the F30 forums:
http://www.f30post.com/forums/showth...ance+automatic
      03-16-2014, 01:16 PM   #3
ianfp
ianfp's Avatar
Drives: X5 40D M Sport
That looks very cool and I like the rest of the carbon wrap too!
      03-16-2014, 01:18 PM   #4
Renaud
Lebanon
Drives: 2012 F25 20i; 2002 E36/8
Looks very nice; I also prefer the glossy carbon. Just a pity that the carbon cover of the central console is not glossy. Perhaps you can have someone clear-coat it for you?
