      03-14-2014, 04:00 PM   #1
Happy jack
Drives: Audi A6
USB Drive / Hard Drive
I seem to be reading conflicting information about these two items
I want to use a USB Flash drive to play music from the USB port in the armrest (actually using a 32gb SD card in a USB card reader)
I also have a 1 tb portable drive with a back up of all my music which I would like to use if possible with a Y cable providing power and data to / from the drive.
What format should the drives be NTSF or FAT32?
Will the BMW support file hierarchy for example letter/artist/album (for example A\Abba\Abba's Greatest Hits) or do all folders have to be on the root? - Just to clear up I don't have any Abba on my Drive!
Is it also the case that the 12v power socket shuts down 15 minutes or so after the engine turns off?
Any help appreciated
      03-14-2014, 05:18 PM   #2
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
I'm using a Seagate GoFlex 500GB formatted NTFS; but FAT32 will also work. All music is in ..\Music. I don't know how the iDrive would index your proposed hierarchy. Easy enough to try on thumb drive with small sample. Yes, the socket powers down. BTW, I'm using only single usb cable with no power problems.
Edit: You could use your hierarchy if you use "Browse Directory".
      03-14-2014, 05:34 PM   #3
Happy jack
Drives: Audi A6
Thanks for that - what I don't want to do is have to reformat or change the file hierarchy in my portable drive because it won't work on my tablet or music system in my caravan. Don't even ask about about portable drives and tablets!
Browse directory sounds good - I am thinking of a Y cable because the X3 I tried didn't seem to have enough power to spin the drive but I didn't have much time to play
      03-14-2014, 07:51 PM   #4
pmeloche
pmeloche's Avatar
Drives: 2013 F25 X3 xDrive35i
You're the Dancing Queen.
Patrice
2013 F25 X3 xDrive35i Vermillion Red
      03-15-2014, 02:35 AM   #5
Happy jack
Drives: Audi A6
Has been said before
I will be dancing when I get my new car in a couple of weeks
      03-15-2014, 03:56 PM   #6
Rogerbu
Drives: X3 GO1 30e M Sport
I am using a 500GB hard drive with a Y cable. Loaded with 20GB of music
I have a file directory of
Music
Album1
Track 1 etc
Album 2
Track 1 etc
I can't remember if it is FAT32 or not.
Works a treat.
Roger
      03-16-2014, 03:51 PM   #7
bowler_1
Drives: 2011 E70 X5 4.0D M Sport
Music
Album1
Track 1 etc
Album 2
Track 1 etc
Works a treat.
Roger
Hi
Does anyone know if the USB connector in the passenger glove box can also be used to play music through the sound system?
