      11-13-2015, 06:51 AM   #1
robe033
Drives: iX1 2023
Coasting Sailing
I coded my 2012 LCI F25 to enable Coasting
Works fine
Enable coasting check box shows in Eco Pro config screen
Blue Coasting icons in Eco Pro screen
Needle stops on line and glows blue
Revs drop and car coasts
Icon does not show in HUD, does anyone know if it should
      11-21-2015, 04:28 PM   #2
zalagan
Drives: 2015 X3 2.0D Xline
I had assumed that coasting mode ( EcoPro coasting driving condition ) was enabled by default in my 2015 xline 2.0d but I've never managed to get it working. The manual states that it is available (page 191 and 194) but I can't get it to work and was beginning to think I either had a fault or BMW had disabled it. To get the car to disconnect engine and gearbox for coasting you must:
1. Be in EcoPro mode
2. Not have turned DSC off
3. Be within the "dynamic boundary range" 30 to 100 mph and not on a steep slope
4. Not be using cruise control
5. Not be towing
6. Have a battery charge neither too high or too low ( )
7. Be in standard D drive
8. Have automatic gearbox
9. Be at normal operating temperature for engine
I have tried to get the X3 to coast on a flat motorway at around 70mph but have never seen it activated. Also the coasting setting does not appear in my setting screen for EcoPro. I don't have the sport autobox, just the ordinary auto.
Can you let me know which coding value have to be changed to enable this?
Thanks
      11-21-2015, 04:34 PM   #3
Peter_R
Air Vice Marshall
Peter_R's Avatar
Works fine
A 2012 LCI F25? I thought the Life Cycle Impulse (LCI) was introduced in 2014 for the 2015 model!
https://en.wikipedia.org/wiki/BMW_X3#F25
Edited...Ah....I now see you are driving a X3 35d Sport 2014, so the 2012 statement is a typo.
      11-21-2015, 11:25 PM   #4
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
How do you code this?
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green
RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black
      11-22-2015, 10:53 AM   #5
robe033
Drives: iX1 2023
I coded the following
CAFD_00000DED (HU_NBT)
SAILING_COUNTER: aktiv [01]
EFF_DYN_SAILING: aktiv [01]
CAFD_0000023F
Segeln: aktiv [01]
CAFD_0000067B
C_Segeln_vorhanden: enable [01]
IcmKod_B_AuskuppelnOK: aktiv [01]
CAFD_000009C8 (kombi)
FZG_Ausstattung::SEGELN_ENABLE: aktiv
      11-23-2015, 04:12 PM   #6
zalagan
So why have BMW disabled this? They must have made a last minute change to the LCI spec as it's described in the manuals. Factory coding error? Unlikely and would have been corrected as soon as spotted. So that leaves coasting being disabled as a saftey thing. Question is, was that because of potential litigation for rare accidents or is there a more serious risk when an X3 coasts and the engine is disconnected from the transmission?
I paid for Efficient dynamics and expect all the F25 LCI features to work as advertised. Think I'll raise a warranty item before coding and relying on this. Thanks for posting the coding details.
      11-24-2015, 01:27 PM   #7
robe033
Drives: iX1 2023
When I raised it BMW said it should be enabled
They updated software
Then said it is only enabled from March 2015 production
Let me know how you get on
      11-24-2015, 02:41 PM   #8
zalagan
Mine was built 27 Feb 15 - will get dealer to code it to car
      03-07-2016, 04:14 AM   #9
V4LKyR
Drives: 2014 BMW F20 1.18i M-Sport
Hello,
I am in the same situation with you, I've coded the necessary codes, even got the option "coasting" under ECO PRO settings, but my revs don't go idle. What am I missing? What happened in your case? Btw, I have an F20, June 2013 made 118i with M-Sport Package, ZF8 automatic transmission.
Thanks in advance.
      03-07-2016, 07:28 AM   #10
Andy_o
Andy_o's Avatar
Drives: X3 20d Xline Melbourne Red
  [0.00]
2015 BMW X3   [0.00]
I believe it's market specific and it is not enabled in the UK
Gone: E90 crimson red/black
Gone :X1 23d Msport manual, Space/Beige Pro Nav, Adaptive zenons, privacy glass, 18's, ext storage,
Current: X3 20d Xline auto, Melbourne/Beige, Sport seats, Viz pack, heated steering wheel, Folding mirrors, privacy glass, luggage net, pro nav
Current: E85 Z4 3.0si roadster titanium/Syrah individual
Current: F31 320d touring black/black work hack
      03-07-2016, 04:33 PM   #11
zalagan
It can't be VO coded by a Uk dealer unfortunately and BMW refused to make a change to UK spec.
      03-08-2016, 02:25 AM   #12
Pinewood
Pinewood's Avatar
Drives: BMW X3 30d M sport LCI
My car is a 09/2014 lci model and has the coasting function. There is one road (the slip road of the A40 into Paddington basin) where i see the blue pedal icon come up. Has to be in eco mode though.
      03-08-2016, 10:21 AM   #13
Andy_o
Andy_o's Avatar
  [0.00]
2015 BMW X3   [0.00]
That's not coasting
The car knows there is a speed limit reduction ahead and in Eco pro mode gives you a hint ( blue pedal) to back off the gas
As an aside it pisses me off that the nav system knows the speed limits but does not show it
Wife's c class showed speed limits in the nav display
      03-08-2016, 02:50 PM   #14
Pinewood
Pinewood's Avatar
Originally Posted by Andy_o View Post
That's not coasting
My bad, you are right. I have a 2016 218d cruiser (read big box), whilst my car is in for a service, and that has lim and coasting functions in the iDrive.
      03-08-2016, 03:43 PM   #15
Peter_R
Air Vice Marshall
Peter_R's Avatar
That's not coasting
I did not know that! Are you sure it is the nav system that knows this? Is this documented anywhere? For this to happen it needs to be embedded in the UK map data such as NBT 2016-1 (Pro Nav).
From what I have seen from pictures some time ago of the nav screen in the US, the speed limits are displayed, but this information is/was picked up by a small onboard camera. Perhaps this is all to do with limiting the speed in other markets and not UK.
      03-17-2016, 05:58 AM   #16
robe033
Drives: iX1 2023
It is definitely from Nav, also warns to slow down when approaching roundabouts and junctions.
I have speed limit display - think this uses NAV as well as camera
      03-17-2016, 09:32 AM   #17
Peter_R
Air Vice Marshall
Peter_R's Avatar
Thanks for this information. There is a lot more to this than meets the eye.
1. I have just spoken to my BMW Tech friend who is getting me more information because there is an option that might/can be retrofitted to my car. Some things happen that are very subtle and you would need to drive 2 differing software standard cars for several weeks to notice it. Even then you might not.
2. So the Nav System in cars has the speed limits embedded, but they do not show unless you have specified the appropriate option on build, which means it can be shown in the instrument display if you cycle through it on the stork. It is not an option on my car but it might be able to be retrofitted. Also would be shown in HUD.
3. If you have the speed limit display option the High Beam Assist (HBA) camera is used to pick up the additional information. This is primarily to over-ride say a 60 mph limit shown by the NAV where you come upon a temporary speed limit of say 30 mph. This limit would apply to the speed limiter and additionally would be shown in the display, see Paragraph 1 above.
4. There are other subtle changes and similar to your statement where the car does not automatically change up a gear when coming to a roundabout, but, keeps the car in the lower gear until you past it. Naturally this information has to come from the Navigation Map.
See paragraph 2!
I know we have gone off topic here, but my BMW Tech friend has just rung me back and the relevant options for my car to show the display are:
8TH - Speed limit info
5AS - Driving Assistant
5AT - Driving Assistant Plus
He advise I cannot upgrade but the system does not show any hardware required to be fitted, and originally thought that coding would fix, but he seems to think that a subtle but slightly different camera to the HBA is used with the options.
