      12-30-2013, 06:15 PM   #1
eROCK
Drives: 2013 BMW X3 28i
Question Side mirror no longer tilting down in reverse.
My side mirror stopped tilting down when I put it in reverse. This happened after it was left outside in freezing weather, so I thought it was just frozen shut. But I've since parked it in the garage where it's well above freezing. It should be all thawed out by now, but it still isn't tilting. Has anyone run into this issue before?
      12-30-2013, 06:32 PM   #2
DonC
Drives: 2013 X3 3.5i M sport, etc
Did you check the mirror switch is in the inboard slide position?
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2018 i3S
BMWZ41909.50
      12-30-2013, 06:58 PM   #3
eROCK
One other important thing to mention, my X3 does not have the power folding mirrors. I'll check that switch to see if it makes a difference, but I never touch it so I don't know how it would work one day and not the next. We'll see
      12-31-2013, 12:45 AM   #4
LI2002tii
LI2002tii's Avatar
Drives: G20 M340i
2021 BMW M340i  [0.00]
2019 BMW 330i  [0.00]
2019 BMW X3  [0.00]
The mirror adjustment switch needs to be set to the driver's side adjustment and it will automatically dip...doesn't matter if you have the auto fold mirrors or not!
'19 X3 30i Black Sapphire W/ Mocha
(Current)
'21 M340i Portimao Blue W/ Black/Blue
(Current)
      01-06-2014, 11:22 PM   #5
eROCK
Thumbs up
UPDATE: It was the mirror adjustment switch after all. I always leave it in the drivers side position, and I haven't touched it, so I didn't think this was the case. After further inspection, the switch was "kinda" in the drivers side position, but not all the way. I must have bumped it slightly to where it was somewhere in the middle. Once I toggled it to the right and then left again it started to work as normal. Thanks for all the advice guys!
      03-11-2021, 06:32 AM   #6
fabscud
United Arab Emirates
Drives: BMW X3
You're right thanks unbelievable I was scrolling through all options in the display without success and I started to doubt that mirror ever moved! until I got here!
      03-11-2021, 08:57 AM   #7
mike_MAN
Drives: 2015 BMW X3
Yep, little known fact of BMW cars.
