05-18-2024, 04:04 AM | #1 |
EbMoo
Rep 7
Drives: BMW X3 F25
Exposed wires in trunk gate struts
Hi all.
I have a 2011 BMW X3 F25 which I purchased as a used on. Recently I have been trouble with the tail gate opening itself and sometimes does not want to close. (it stays closed if I lock the car.) After reading multiple threads on this forum, I did an inspection of the struts and I have found out both struts have one 'exposed' or 'uninsulated wire'. I am not sure if this is meant to be like that ? This was simply under the rubber covering with all the other insulated wires Also I was looking for the standard tail gate module, however I could not find one...but then I found a 'aluminum' style box behind the left side of the trunk...this looks like the 'module' you get when you retrofit. Now I am thinking did the previous owner retro fit it ? Does the genuine BMW tail gate module looks like a white box with three inputs on the side ? Can some one please check their X3 F25 struts and see if both have exposed wires ? |
05-29-2024, 05:26 PM | #4 |
EbMoo
Rep 7
Drives: BMW X3 F25
Sorry for the late response, I did a thorough check and found out the tail gate module was next to the battery and yes its a genuine one. I took it out gave it a good clean with contact cleaner and compressed air. Do not believe it has water damage.
I then ran a check with bimmerlink and got this error code however I cannot figure out what is a hall sensor on x3. Is it the two motorized struts that lift the gate up ? |
06-05-2024, 04:31 AM | #5 |
EbMoo
Rep 7
Drives: BMW X3 F25
Yes I located the module next to the battery. Its the genuine BMW module. I have ordered a new one and just got it received today. Will change the module tomorrow and see if it fixes my tail gate issue.
06-20-2024, 04:33 AM | #7 |
EbMoo
Rep 7
Drives: BMW X3 F25
Sorry for the delay in update...was travelling extensively and away from computers and internets.
Well the same issue still exists. Nothing has changed. So I am assuming the module is all good. The latch lock system clicks responding to the button pressess...so I am assuming that's working too. I do have a second BMW X3, same year few months newer...but its parked at a different place. I checked the wires and they are not exposed. I have not had a chance to exchange the tailgate module from that car on to this...not sure if it makes any difference. I also have not found anything helpful with those error codes i received using bimmertool. |
