      02-10-2012, 07:47 PM   #1
Falconx3
Drives: 2012 X3 28i
2000 km review 28ixdrive
For what it's worth:
After 2000k, I still look for any excuse to drive somewhere. No rattles, squeaks or issues. This is an amazingly solid vehicle. I find past reviews understate the fabulous ride, quiet interior and overall build quality. The chassis is tight, and grip outstanding in bad weather. Mileage is bang on above average. The non turbo 3.0l cranks out plenty of smooth and adequate grunt to blow past most others. Control functionality is excellent. And no one to my knowledge has mention the ample rear leg room for this class. And you'd think the wipers read your mind when in intermittent mode. Very clever. Idrive is awesome. And the heated seats heat both the buttocks AND the lumbar (my Merc only does the cheeks).
Just a few nit picks - minor observations, and not whining.
-rears door don't open as wide as the front or as much as I think the should. Takes getting used to. If you don't have kids, disregard.
- no read out display indicator to show the heated steering is on. Yes you can tell, but a variable 3 step temp setting would be nice.
- seating memory lights are not illuminated. Tough at night. And memory function does not adjust mirrors- I think.
- no dash indicator to show rear wiper is engaged.
And finally, my only regret:
- the tail lights for the non xenon version only partially illuminate, that is only the outer portion, even for the brake lights. So unfortunate the unlit tapered portion of the lights on the rear hatch don't illuminate. This makes the rear heat signature awfully mundane for those behind and detracts from visibility to the guy driving on your ass. Wish I had of known in advance. Definitely shell out for the xenons- possibly only available on the 35i? Anyways, even a base, Sportage, Passat or a xc60 have LED tail lights that give a distinctive heat signature in the black. Bummer I missed this.
If any potential tire kickers are researching- this is definitely the best mid-range "SAV/SUV". No hesitation. I've tried or have exposure to the competition and the x3 blows them out of the water in all respects.
Thank you to all posters who have contributed worthy information about the X3 and thank you for reading this post.
      02-11-2012, 07:24 AM   #2
x3heh
Drives: Honda
What about the shifter? Why is it designed backwards? Shift forward to rerverse??
      02-11-2012, 08:20 AM   #3
Earlofessex
Drives: 2012 X3 35i
When in sport manual it is pull for up shift and push for down shift. That's the opposite of my last car (Q5). Not sure which way is "right", but I now need retraining.
      02-11-2012, 08:32 AM   #4
RichardBR
Norway
18
Drives: 2012 BMW X3 30D Msport DSB
Shift forward to reverse are normal for other brands as well. Even manual stick in BMW's...to the left and forward to reverse...
      02-11-2012, 09:06 AM   #5
x3heh
Drives: Honda
Manual reverse is also to the right and pull towards you on other brands.
      02-11-2012, 09:16 AM   #6
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
OP, Is this what you are talking about? Is this feature only available with xenon option?
      02-11-2012, 09:24 AM   #7
Nahoa
It's not backwards in comparison to traditional automatics -- R has typically been forward of D.
P
R
N
D
Pull back to get to D, push forward (and use button) to get to R.
      02-11-2012, 09:28 AM   #8
roundtree
roundtree's Avatar
Drives: '12 F25 28i SB
2013 BMW 328i  [10.00]
2012 BMW X3  [10.00]
Every automatic I've ever had required me to shift forward for R and P, relative to N and D. It seems different because the shifter doesn't slot into the new position. That's definitely a new one for me.
      02-11-2012, 09:29 AM   #9
Nahoa
Would really like to see a dash indicator that the heating steering wheel is on, too. For some reason the lack of a rear wiper indicator doesn't bother me, but I wouldn't mind having it.
The memory buttons do store the outside mirror positions. Not sure I follow about the illumination, unless you mean relocating them, too. Can't see them where they're at while sitting in the driver's seat, can you? For me it's easy to feel the M and storage buttons and hit what I need.
I'd really like to see the European amber rear turn signals vice the red. Not distinct enough. Prefer the visibility of the amber in high traffic areas and hilly, dark, backroads.
