      07-03-2017, 10:34 AM   #1
tomitch
Drives: 2016 X3 28i
not use oem patrs
I'm under BMW warranty on my 2016 x3, does anyone know if I can use other brakes padand parts than oem without affecting the warranty?
Thanks and Happy 4th of July!!
      07-03-2017, 04:10 PM   #2
BOSSBMW
Drives: 2013 X3 35i
you're giving the dealer an opportunity to tell you that your issue (if you were having a brake problem) is a result of the aftermarket parts, but i dont think you would void your warranty permanently.
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX]
      07-04-2017, 11:49 PM   #3
TEF
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
Doesn't the warranty on a 2016 X3 include the replacement brake pads and rotors? I believe mine does. Also, I recall that brakes were not included in 2017 warranties. Have you verified this with your dealership?
      07-05-2017, 07:28 AM   #4
BOSSBMW
Drives: 2013 X3 35i
i didnt think BMW does the maintenance plans anymore ...
      07-05-2017, 08:22 AM   #5
MSport_Jon
Drives: X3 F25 LCI /// F80 M3 (SOLD)
If you vehicle is under warranty, do yourself a favor and if you want to maintain yourself the vehicle use only OE parts... BMW will blame your parts and yo' mama for anything that is directly and indirectly broken. Do not give BMW ammo to shoot you down with.
      07-05-2017, 11:59 AM   #6
dreamspeed
dreamspeed's Avatar
Drives: 6MT
I'm assuming the OP is the second owner? BMW cheaped out awhile ago and made the free maintenance plans non transferable to the second owner starting in 2014 iirc
      07-05-2017, 08:19 PM   #7
JE_335i
JE_335i's Avatar
Drives: 2008 335i Coupe
Maintenance warranty follows the car not the owner. This is through 2016 models. Brakes are covered under 4/50,000 warranty. No aftermarket part will void warranty unless it is causing the issue.
Tags
oem or not?
