      05-26-2017, 10:56 AM   #1
X3BMW
Drives: 2013 white/black X3
headlights
Just saw that condensation has formed in sealed headlight. Any idea how to fix this?
      05-26-2017, 10:46 PM   #2
ba ba boosh
Drives: Jalopy
It should clear up after a few days, but if your car is under warranty, then bring it in for replacement I suppose.
      05-28-2017, 09:43 AM   #3
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
I had this issue once after a dealer car wash. I used a blow dryer to heat up the headlight from the outside while using a vacuum to suck out the heated condensation . I did this at night when it was cooler.
I had to hold my hand over the opening to help get suction.
      05-31-2017, 11:29 AM   #4
X3BMW
So you removed circle cap from back of housing and then somehow stuck the vacuum hose in that little area?
      06-03-2017, 02:53 PM   #5
VikingOne
VikingOne's Avatar
Drives: BMW G30 530e 2018
I bought some large Silica Gel packs from Amazon, and opened the black cap at rear of the lights, and popped a pack in each light, and put the cap back on. After a couple of days the condensation soon cleared up. I am tempted to leave them in if it re-occurs.
Previous: 2011 X3 2.0d xLine
Previous: 2015 X3 LCI 3.0d xLine
Current: 2018 530e 2L M-Sport I-Performance
      07-05-2017, 09:56 AM   #6
MSport_Jon
Drives: X3 F25 LCI /// F80 M3 (SOLD)
Some headlights are not sealed and have vents for ventilation. The LED headlights have this as well as a fan inside the headlight assembly. Moisture builds in there if the headlight is not used. The fan takes care of this problem. Not sure which headlights you have but chances are they are not sealed.
      07-05-2017, 10:00 AM   #7
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
I had mine replace under warranty, had pics as evidence
