      07-25-2012, 03:04 PM   #1
dabestballer
Drives: '11 X3 35i Alpine White
Lightbulb Replacing the interior lights
I just bought LED interior lights for my X3 but I can't seem to figure out how to replace the front dome light and the 2 rear lights with reading lights.
Any one knows how I can open the light casing so i can change the bulbs?
      08-27-2012, 06:14 PM   #2
redframe85
redframe85's Avatar
Drives: '99 E46 '08 E93 '11 E70 13 F25
can anyone help? i'm stuck in between
      08-28-2012, 12:27 PM   #3
chx437
Drives: BMW X3(G01)
In the German X3 forum there's lot of info and pictures as well on changing interior light bulbs to leds:
http://www.motor-talk.de/forum/innen...?highlight=led
http://www.motor-talk.de/forum/eine-...-t3735148.html
...text is mostly in german but some English as well and also some good pictures are included
      08-28-2012, 03:34 PM   #4
electricjet
electricjet's Avatar
Drives: 2011 E90 & F25
help with front & back domelight removal
front:
looking from below up:
you will see a black trim piece witch surrounds the moonroof switchology and bmw-assist cover .. using a plastic trim removal tool or a credit card very gently pry the aforementioned trim piece out ... this will reveal 2 "L" shaped holes ... using a flashhlight and a flat-head screwdriver press the metal clip (one at the time) you towards the center of the overhead domelight enclosure while gently pulling down on the outside of the domelight enclosure (go gentle yet firm)
this will release the domelight enclosure and you will be able to access both maplights and the domelight
aft:
the aft domelights are removed by (looking aft) lightly pressing aft and pulling out (on the front of the domelight enclosure)
call if you need help
following led's are suggested for the f25:
canbus error free led's for the dome & maplights
regular led's for the door, foot-well and trunk lights
for more light in the trunk i found that a 9 sim led generates a nice lighted area versus using a 5 sim led
for people interested i can post links as of where to obtain led's from ebay
9194267730
DRIVE IT LIKE YOU STOLE IT
      12-13-2012, 11:55 PM   #5
ekor
Drives: X3
Hi Electricjet,
I'm interested in the ebay link. Please post. Thanks.
Originally Posted by electricjet View Post
front:
aft:
9194267730
      12-15-2012, 01:13 AM   #6
jaybee88
Drives: 2012 X3
front:
aft:
9194267730
How do you find the quality of the eBay LEDs and the brightness output from them?
      11-17-2013, 10:29 PM   #7
Bladespeed
Drives: 2013 x3 3.5 m package
Hi electricjet,
Newbie in the forum. Trying to follow your instructions
And i'm having a hard time.what about the dome light in
The back? Is there a way you could post pics/videos on
How to do it properly?
Appreciate it.
Bladespeed
front:
aft:
9194267730
      11-18-2013, 07:57 AM   #8
EvilGenius
Drives: 2014 BMW X3
Originally Posted by Bladespeed View Post
Hi electricjet,
Appreciate it.
Bladespeed
The back domelight is easy:
If you have a vehicle trim tool (preferred) or a screwdriver, insert it between the headliner and the light assembly at the front of the light assembly. In the middle is a clip holding the light in, give a push with your tool and you will feel it disengage the clip and the light will freely pop out of the enclosure.
      11-21-2013, 01:16 PM   #9
Bladespeed
Led
Just left the car in dealership for rustproofing. Will try it once i get it.
I got the front,footwell,vanity and glove compartment. Just stuck with the back.
Appreciate the info. Will post if successful.
Bladespeed
      11-21-2013, 05:28 PM   #10
Bladespeed
Led interior dome lights
Which part is the front of the light assembly? Is it the top or bottom towards the door?
Thx.
      11-22-2013, 06:49 AM   #11
EvilGenius
Drives: 2014 BMW X3
Thx.
Front = the side facing the front of the car.
      11-27-2013, 07:53 AM   #12
Bladespeed
Led
Thanks evil genius..
My project was a success. Appreciate the help.
Bladespeed
      12-27-2013, 12:25 AM   #13
Toast
Toast's Avatar
Drives: X3.5m, A4 Avant
I replaced my trunk and foot well lights with the following
9 pin LED canbus error free
5 pin LED canbus error free
Is it wrong to use canbus error free throughout the interior?
X3.5m | A4 Avant
      02-17-2014, 03:14 PM   #14
bowler_1
Drives: 2011 E70 X5 4.0D M Sport
Change front interior light for LED's
Hi all, I have just joined the forum. I have previously owned an X5 and X1 but have just purchased a 2013 X3 X-Drive 2.0D Auto M Sport and want to change the front interior bulbs for LED's
I have seen the other posts but can't make any sense of the suggested German post.
Has anyone done a similar change and can advise me what the correct procedure is please as I don't want to do any damage to the trim or light fitting .
I have downloaded the various Tech manuals on the forum which look interesting but I can't find any mention of actually changing the lights.
      02-17-2014, 08:06 PM   #15
flavius
Drives: 2019 440i Gran Coupe
Did you try online translation?
      02-18-2014, 04:04 AM   #16
bowler_1
Thumbs up Overhead interior lamp replacement
Hi flavius,
thanks for that tip, as an oldie it didn't cross my mind but it worked well when I did the translation. Obviously needs some care and a bit of careful force
      02-18-2014, 10:12 AM   #17
Gouda
Drives: 2011 X3 35i
2011 BMW X3 35i  [0.00]
So, why change to LEDs? Only if the originals burn out or? Are they brighter or a different color temp? In some uses I understand like rv's where battery life is important. Just curious.
2011 X3 35i, Black Sapphire, Nevada, professional Nav, premium sound, sport seats, Primacy MXM4's. etc., etc.
08 Wrangler Sahara Unlimited for the OHV park.
      02-18-2014, 02:01 PM   #18
bowler_1
Overhead light replacement with LED's
I have already changed the boot lamps and the difference is very obvious.
I am expecting HID's for the main headlights this week. The existing headlights lack definition and distance .
Main reason for changing is that the LED's give a whiter/cleaner light. Will also change rear interior lamps to LED's.
UPDATE 13/03/2014
I have just changed all interior lights with CANBUS LED's and very pleased with the results and no error issues.
Once you work out how to remove the first rear dome light as described above it becomes easy to replace the other one, its getting the tool in the right position to press in the clip, which is situated in the middle of the front edge of the light fitting, that is the tricky bit.
Also another point I found is that when removing the footwell lights it is the white part that is released at one end and NOT the whole fitting. You just need to gently prise out the end nearest to the door and the white fitting just slides out. Hope this helps someone.
I purchased my 5 LED CANBUS LED's from E-bay (6 Error Free Canbus T10 194 168 W5W 501 5050 5 SMD LED White Car Side Light Bulb, 12 for £9.98) and they worked perfectly and of course they operate without the high temperature of normal bulbs !!!
Last edited by bowler_1; 03-13-2014 at 11:36 AM.. Reason: Update from previous post
      09-06-2014, 10:08 PM   #19
E60orBust
Drives: "The Brothers //M-Sport" E90/2
Some pictures to help illustrate the tabs and center overhead unit for future web crawlers
Pic 1 is of the rear dome/map lights. The tab is on the side with the circular light, right in the middle. Just give it a push with a flat screw driver and the unit will pop down.
Pic 2/3 is of the center overhead. There is a small decorative trim piece going around the SOS/Sunroof/Airbag warning light. I popped it off with a sharp pocket knife. Behind that trim there is the L pocket on each side, push that in (third pic) and the cluster can be pulled down.
Down for Maintenance
      11-08-2014, 12:11 PM   #20
chx437
Drives: BMW X3(G01)
Has anyone tried to replace the three bulbs in the front dome of the new 2015 X3 LCI?
The front dome in new X3 LCI seems to be a bit different than in the pre-LCI models, e.g. it does not have any more a surrounding "easy to remove" trim. Any ideas how to remove this new dome and to get access to the traditional bulbs (3 x 5W5)?
      02-06-2015, 11:31 AM   #21
zzz
Belgium
12
Drives: G31 520i
I am interested as well, did you manage to remove it? I was able to pull it a bit down, but then it got stuck.
520i Touring
      02-07-2015, 11:54 AM   #22
chx437
Drives: BMW X3(G01)
More about changing interior lights to LEDs:
http://x3.xbimmers.com/forums/showthread.php?t=1064169
I did manage to remove the front dome according to jonsc advice:
" It is really easy on the LCI. the entire unit is held in by those easy to open clips. Just start from one side and work your way around it should easily pop out"
However I must admit that some of the clips were quite hard/tricky to open!
Tags
interior bulbs
