      07-15-2015, 08:54 AM   #1
Kimo
Drives: E31 E90 F25 MCS
Hakka R2 SUVs - Correct Tire Pressure?
Hey all
Patient is a 2012 X3 28i, laying out its winter clothes.
Just mounted some 225/60-17 Nokian Hakkapeliitta R2 SUV RunFlats on dedicated winter wheels, and while the shop was obviously able to find the listed pressure for the stock 245/55-17s, it found nothing for the modified 225/60-17 size for the snows. I couldn't either. They are currently at 35 but I'd like to get it right.
Can I hear from guys who are running the Hakkas on 17s? What is the proper pressure for winter conditions?
Thanks
      07-15-2015, 09:21 AM   #2
mge92
SPEED RACER
mge92's Avatar
Drives: BMW X5 M50d BMW M2 CS
Filling your tires to what the door jamb says should be fine.
2019 BMW X5 M50d Artic Grey | 2020 BMW M2 CS Misano Blue
Incoming - Ginetta G56 GT Academy | Incoming - BMW X5M Comp Oxford Green
RIP - 2020 Mini JCW GP Racing Grey | RIP - 2013 X3 xDrive28i Carbon Black
      07-15-2015, 11:24 AM   #3
Kimo
Thanks for the response. Answering my own question here for posterity.
This (paraphrased) guidance from Both TireRack (sold the wheels) and Tires-by-Web (sold the tires).
"If you go with 225/60R17, then to maintain load I would keep the front and rear at 35 PSI with a standard load tire (or with an XL rated tires 42 PSI on the rear)."
Since the 225/60R17 R2 SUV Runflat is definitely NOT an XL-rated tire, I'll go with 35 pounds at all four corners.
