      12-22-2015, 11:26 PM   #1
Toppower
Toppower's Avatar
Drives: X3 35i M-sport
Does Style 305 on a X3 35 fit?
Can anyone confirm that Style 305 wheel with 225/60/17 DOES or DOES NOT fit on a X3 35?
This has been an ongoing debate but I cant seem to find the answer or pictures to prove this.
ANYONE ?????
Thanks
Live For Today!!
      12-23-2015, 04:24 AM   #2
Scandic24
Scandic24's Avatar
Sweden
45
Drives: X4 30d MSport
Unless there are some magic going on I'd say the 305's with 225/60/17 will fit on a X3(F25) 35iX, and the reasons are:
- Both 304 and 305 fits the F25 28iX (US).
- The 304 also fits the 35iX, therefore the 305 should also fit the 35iX.
- 304 and 305 are exactly the same size - width, diam and ET.
- The 225/60/17 tire are of course a bit narrower but have the same circumference as the 245/50/18 which seem to be std on some 35iX's.
Edit: You can verify my info here: http://www.etk.cc/
Edit2: Weight should not be an issue - The 305 are available for the 30d which is heavier than the 35i.
      12-23-2015, 09:00 AM   #3
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
Yes it will fit. See http://www.bmwstylewheels.com/bmw/305
Although they are 17 inch rims they will clear the brake calipers with little space compared to 18 inch rims. I have oem bwm 17 inch winter rims with 225/60 size tires and no issues.
      12-23-2015, 11:48 AM   #4
Portimao318
Portimao318's Avatar
61
Drives: BMW 318i Touring MSport
I have 305 wheels, with 225/60/17 wintertires on my X3 X-Drive (2015 model), however its not a 35i, but 4 cil.
2022 318i Touring MSport Portimao blue
      12-23-2015, 12:41 PM   #5
A1traveller
Drives: 2017 F25 xdrive 20d M Sport
What other models use the 305 style wheels?
X3 Xdrive20d M Sport Auto,M Sport plus package, Media Professional Plus package, electric folding towbar, reverse camera, convenience access, HUD, Space Grey
      12-23-2015, 01:22 PM   #6
brissim
Drives: X3 30d (2011 F25) - now sold
As people have said - the 305 should fit no problems. I've 17" 306 on our 30d. The only exception will be if the X3 has the M Sports package with its larger-than-standard M Sports brake caiipers (or the M Sports brakes as a standalone option). In this case you I believe you need a minimum 19" wheel to clear the brake calipers.
Tony
      12-23-2015, 11:00 PM   #7
Toppower
Toppower's Avatar
For some unknown reason BMW states that they ONLY do not fit on x3 35s.
Live For Today!!
      12-24-2015, 09:13 AM   #8
Roundown
Likely brake clearance or heat.
      12-24-2015, 10:23 AM   #9
Scandic24
Scandic24's Avatar
Sweden
45
Don't think so. The 305's fits the 30d, which has exactly the same brake discs and calipers as the 35i. Performance are similar.
