      09-11-2022, 09:45 AM   #1
itsnota2ma
itsnota2ma's Avatar
20
Drives: 2012 550i xDrive Msport
Need help: 2014 NBT MMI
I installed a used NBT MMI, and when I switch to the MMI, the screen pops up for half a second and then goes blank. It has the smaller screen so I have dip switch 3 in the off position. I do have an 8" screen for an X25, but I believe the X3 has to be programmed for it to work. The model number of the MMI is NBT-1904-LC. I believe it is an Andream unit.
Any help with this would be appreciated! Thanks!
      09-11-2022, 03:45 PM   #2
itsnota2ma
itsnota2ma's Avatar
20
Update: So after buttoning everything up, the unit is working, well, mostly. I am not sure what was wrong. Anyway, unit is in, performed updates. Seems Android Auto works over USB only on this unit. No sound. I have the iDrive set to AUX, I have the unit plugged into the Aux port in the arm rest. I am probably missing a setting, not sure which one...
      09-17-2022, 11:56 AM   #3
itsnota2ma
itsnota2ma's Avatar
20
Anyone??
      11-18-2022, 09:10 AM   #4
itsnota2ma
itsnota2ma's Avatar
20
Mueller??
