      07-15-2014, 10:33 AM   #1
chx437
Drives: BMW X3(G01)
Tail lights on new X3 F25 LCI: LEDs ?
If you select the new LED head light option for the LCI X3 so you get also head blinkers as LEDs. How is it then with the tail lights: do you get the same LED stripes for your tail lights as with the Xenon head lights? What about then the tail blinkers or break lights: are they also LEDs (when you have LED headlights) or do they use the old glow bulbs as they have been with the pre-LCI model?
Perhaps owners of the new LCI model with LED headlights could clarify "LED status" of their taillights.
      11-19-2014, 10:13 AM   #2
mhayden
mhayden's Avatar
Drives: 2015 BMW X3 (F25 LCI)
I picked up the LED headlight option on my F25 LCI X3 that I bought in September but the tail lights aren't LED's. The brake light as well as the turn signals are plain old bulbs (which doesn't make much sense). My 2011 335d with the upgraded lights had LED turn signals in the back with plain bulb brake lights.
      11-20-2014, 05:13 AM   #3
chx437
Drives: BMW X3(G01)
Yes I found the same also: even with LED head light option you get the old (pre-LCI type) tail lights with blinkers, break lights, reverse lights and fog lights using old traditional glow bulbs. Fortunately the actual parking lights with LED stripes are still there.
So as a LED fan I let my friend to code the car so that tail lights are changed to LED -type instead of bulbs. After this coding the car is monitoring the tail bulbs only for short circuit and you can replace the bulbs with LEDs without error messages (and you don't need e.g. external parallel resistors). Currently there are quite bright LED bulbs available e.g. in the format BA15S (P21W) both in amber and in red fitting quite nicely for the X3 LCI (and also for pre-LCI) tail lights
      11-20-2014, 06:40 AM   #4
Bimar
Bimar's Avatar
800
Drives: Bmw X
Full LED in BMW=Series 5 and above...shame!!!
      11-23-2014, 09:20 PM   #5
mk3
Drives: 2014 X3 28i
Originally Posted by chx437 View Post
............ Currently there are quite bright LED bulbs available e.g. in the format BA15S (P21W) both in amber and in red fitting quite nicely for the X3 LCI (and also for pre-LCI) tail lights
So how do these BA15S led bulbs look? Do they look like the wimpy weak "spot" led aftermarket bulbs I've seen on other cars or do they have the same brightness and appearance as the regular type bulbs? I want it to look like a BMW, not a car with crappy aftermarket junk.
      11-23-2014, 09:29 PM   #6
Bimar
Bimar's Avatar
800
Drives: Bmw X
Car pics with LED retrofit will be helpful
      11-23-2014, 11:07 PM   #7
jonsc
Drives: 2015 X3 M Sport
I took a quick video after I installed the LEDs last month. I replaced the front turn signals, rear turn signals, and brake lights with LEDs and then coded the car to not throw an error message.
MK3, they will not look wimpy if you buy high power LEDs. The first ones I bought were cheap and small and definitely did look wimpy but the newer (and more expensive) ones I bought are extremely bright and look much better than OEM halogen bulbs.
https://vid.me/6ds2
      11-23-2014, 11:26 PM   #8
Bimar
Bimar's Avatar
800
Drives: Bmw X
https://vid.me/6ds2
That looks cool, can't understand why BMW cheap skating on this. can you share the site you bought the LEDs?
      11-23-2014, 11:50 PM   #9
jonsc
Yeah, I couldn't believe they still use halogen bulbs....
Rear brake and turn signals: http://www.ebay.com/itm/231347086940...%3AMEBIDX%3AIT
Front turn signals: http://www.ebay.com/itm/191365298660...%3AMEBIDX%3AIT
For some reason, even though they are CANBUS LED's (error free), they still throw errors so I just coded it out.
      11-24-2014, 12:34 AM   #10
mk3
Drives: 2014 X3 28i
Looks great! Man I want those side mirrors on mine.
      11-24-2014, 08:40 AM   #11
Bimar
Bimar's Avatar
800
Drives: Bmw X
Wait aren't the side mirrors already LEDs?
      11-24-2014, 11:41 AM   #12
mk3
Drives: 2014 X3 28i
I have a 2014, no lights on the mirrors.
      11-24-2014, 11:46 AM   #13
Bimar
Bimar's Avatar
800
Drives: Bmw X
Gotcha!
      11-24-2014, 04:48 PM   #14
droftrah
Drives: '18 G01 X3 M40i
I changed my brake lights and signals front and rear out to led's a while ago on my 13, so glad I did, looks great! especially on the front theres no orange glow coming from the housing with the light off. I also got the black reflector overlays for the amber reflectors so theres no orange visible on the front of my car other than when the bulbs are on/flashing.
I do have an issue with my rear led turn signals though..... when locking/unlocking the car or when using the flashers (when both signals blink simultaneously) the passenger side bulb has a delay about 2/3 of the time (the driver side blinks on and off slightly before the passenger side) making them off time.
When I un-code the error checks they work fine, but then I get bulb out errors and hyper flash.. with the errors coded away, I get the off time blinking in the rear. Any ideas?
