      08-08-2013, 05:45 AM   #1
wurley07
Drives: bmw x3 msport 3.0sd
X3 20" x5 wheels
Hi guys do 20" x5 wheels fit straight on a 2008 x3 3.0 sd
Ok know the narrower wheels fit but not sure about the wider msport wheels
The wheel sizes are
Front 9.5x20 45 offset centre bore 74.1
275/40 tyres
Rear 10.5x20 30 offset centre bore 74.1
315/35 tyres
I know I need 72.6 spigot rings
Will there be enough clearance on arches shocks calipers ok
Cheers Jon
      08-21-2013, 10:09 AM   #2
eXhilarat3d
Drives: '13 AW 528i & '06 AW X3
From the research I have done, the front wheels will fit the E83 but may need a smaller tire. Something around 275/35-20. You are correct about needing hub centering ring to go from 74.1 to 72.5.
You may need to look for a set that's 9.5 in wide all around. That is my intention when I'm ready to buy wheels.
