      01-11-2016, 08:08 PM   #1
JohnAG
Germany
12
Drives: 2016 X3 28i M Sport
Turn indicator lights on the HUD?
So I've been coding my car and was successful in some (i.e. replacing the start up manufacturer disclaimer with the M logo at start up, doors unlock when engine is turned off, etc.) while not on one thing, that is having the turn indicator lights appear on the HUD. According to the cheat sheet I'm using, this should be possible, and I was able to make the change in the coding itself, even confirmed it after I made the change by going back and ensuring the change took place. Has anyone else experienced this? Thanks in advance.
      02-09-2016, 10:18 AM   #2
bichoo
bichoo's Avatar
Drives: BMW X5 40i M-Sport
I tried it last night on my 2016 X3, enabled it but I do not see it working in the HUD
      02-10-2016, 02:22 AM   #3
apbx3
Drives: 2014 BMW X3 (3.5i)
I had mine coded and it works perfectly , I wish the stations would be in the hud
      02-10-2016, 02:23 AM   #4
apbx3
have you tried coding the idrive touch controller
      02-11-2016, 09:05 AM   #5
bichoo
bichoo's Avatar
It's working now! You have to enable it in a few areas and for some reason, the changes had not saved but its fine now. The only thing I'm disappointed about is that both turn signals appear with one greyed out. I wish only the active signal would appear
